Electronic Ignitions
What Electronic ignition units are people using in their Sprints? Luminition say their may be a problem using their systen due to the low distributor cap but they think people have tried them, they just dont know if they were sucessful. It would be good to hear from someone who is using one<br>
Ive looked back through the archives & Piranah is mentioned but they had a poor reputation many years ago - the one my Brother had only lasted a few months. I know they are probably a different animal altogether now but Id rather stick with Luminition as Ive not had a problem with one in 20 years<br>
Their Magnetron system will work but the Optronic system is a better unit so would be preferable if someone knows they are OK. It has been suggested that a slightly higher distributor cap can be used to give extra clearance - anyone heard of this? what off? (Ive seen Maestro 1300 mentioned) Presumably the manifold would need modifying to allow space.<br>
Has anyone tried using the system from the Metro / Maestro on the Sprint?<br>
Too many questions I know, but any help appreciated.<br>
Les
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 20/10/06 10:58 am<br></i>
Les
Shaun Naylor
Electronic Ignition
I use an Aldon Ignitor (LU143) everything is inside the distributor and you can use a sports coil with it, but you have to use the clubs alternate cap, arm & leads for clearance. It's also cheaper than the luminition
Stephen Grellet
Electronic Ignition
I have used the Newtronic (Pirhana) ignition for about 9 years and it has never given any trouble at all. These are available at http://www.newtronic.com <br>
Regds Stephen
Regds Stephen
Stephen Grellet
Electronic Ignition
Don't be too quick to discount the Pirahna system. I've been using the same Newtronic system (Pirahna) for over 9 yrs and 35000 miles. I heard that they don't like the damp much so I mounted the black box inside the car, up behind the dash. Perhaps that's the secret. However, I've always followed the advice of Jamie Weidner (remember him ?) and kept a points conversion kit in the car, just in case <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
speedracer
Re: Electronic Ignition
My programmable ignition kit is fired by a Pirahna optical trigger - works well.<br>
speedracer
<p><!--EZCODE LINK START--><a href="http://www.triumphowners.com/2">1975 Dolly Sprint</a><!--EZCODE LINK END--></p><i></i>
speedracer
I am using Magnetronic on my Sprint with std distributor cap, 4 years service up to now with no problems.
Joshesspit
proggramable ign
hello<br>
what is the proggramable ignition you use??<br>
cheers<br>
cheers<br>
Lumenition ign
I have run my Sprint for over 10yrs on Lumenition without any problems and have fitted it to other peoples Sprints
Re: proggramable ign
the programmable kit that both speedracer and i use is from Sprintparts in aus.<br>
<!--EZCODE AUTOLINK START--><a href="http://www.sprintparts.triumphowners.co ... <!--EZCODE AUTOLINK END--><br>
its a good bit of kit.
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--></p><i></i>
check p/leads
just been on <br>
<!--EZCODE AUTOLINK START--><a href="http://www.sprintparts.triumphowners.co ... <!--EZCODE AUTOLINK END--> for the first time check the plug leads they have cool!
Luminition
Do you run the Luminition with standard cap etc?<br>
Les
Les
