removing front wings
Locked
1300dolly
#1 Post by 1300dolly » Thu Jul 20, 2006 6:14 pm
without damge, how is this done , (1300fwd)? i have the door off but can not see where its spot welded.<br>
i have to remove the wing to fit the inner which has been ordered.<br>
J.
Nathan MWK 627G
Re: removing front wings
#2 Post by Nathan MWK 627G » Thu Jul 20, 2006 10:21 pm
apparently you cant take them off without damage...iv been told to either chisle them off or use an air saw!! also the front headlight holder needs to be parted from the wing!! iv got 2 nos front wings waiting to be fitted to mine but i havent plucked up the courage to do it!! iv spoken to canley classic's about this...he said that if he was to do them he'd want £35 an hour and a whole day to do one side!! if i was to do them he'd recomend 2 days a side!! im only saying whats has been said to me so ill leave it up to you.<br>
the only other person i know on here with a 1300 fwd is bruce jones, hes done a complete resto with modifications on his and he might be able to help you some more!!<br>
good luck with the project!!<br>
1968 1300 fwd
1300dolly
#3 Post by 1300dolly » Thu Jul 20, 2006 10:32 pm
i think i will wait till the inner turns up then go from there (gulp) this was an easy get back on the road project.<!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/images/emoticons/ohwell.gif ALT=":"><!--EZCODE EMOTICON END--> <br>
J.
dollysteve
#4 Post by dollysteve » Fri Jul 21, 2006 8:15 am
I`m so glad the mies not rotten they do look a nightmare to take off. Mind you my car has had about three complete new front ends during it`s life after nearly being written off on a few occasions.
2F45T4U
#5 Post by 2F45T4U » Fri Jul 21, 2006 4:02 pm
Sounds familiar <!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
1300mash
Jammy sod
#6 Post by 1300mash » Fri Jul 21, 2006 7:52 pm
I know it's no help, but mine were bolted on when a previous owner replaced them first time around which made it very easy! <!--EZCODE EMOTICON START :b --><img src=http://www.ezboard.com/images/emoticons/tongue.gif ALT=":b"><!--EZCODE EMOTICON END--> You could see where they'd had to cut off the bit of front panel where the headlamp fits though. If this part is bad and you need a template I have a new front panel which I'm saving for a rainy day...<br>
By the way if anyone needs 1300 front wings I'm told Hadrain Panels still have some for around 40 quid each.
Triumph1300
Take cold chisel in hand........
#7 Post by Triumph1300 » Fri Jul 21, 2006 9:29 pm
When we took KAC's front wings off, which are the same one's as it wears today, it was done like this...<br>
Remove headlamp mounting panel, and sidelight/indicator assembly.<br>
Clean up the top mounting channel, sill flange, and front edge with wire brush in angle grinder to locate spot welds. <br>
Drill out spot welds with spot weld drill. Leaves nice holes for plug welding back on!)<br>
There were no welds on the rear flange, ie A post joint.<br>
At the joint between the wing, and front panel, ie where the indicator is, the joint had been brazed, and this was heated with a torch to seperate it. Apparently this should have been welded. <br>
Then using a thin chisel/scraper, the joints were seperated, and we put the Kettle on!<br>
It took a couple of hours to do, and to be fair, when it came to re-fitting, having fitted new inner wings, it took a long time to get the alignment correct, but it is worth it in the end.<br>
If you want to talk it throgh further, feel free to give me a call.<br>
BWJ<!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/images/emoticons/glasses.gif ALT="8)"><!--EZCODE EMOTICON END--> <br>
slant04
wing removal
#8 Post by slant04 » Fri Jul 21, 2006 10:40 pm
I agree, perfectly possible to remove and refit an old panel with care. If I recal there are a few tack welds along the rear seam of the wing . You wull notice the door end, mor or less in the middle of what looks like one panel - one part belongs to the a-post - a light chisel after a careful grind
1300dolly
Re: wing removal
#9 Post by 1300dolly » Sat Jul 22, 2006 12:43 am
mine are welded on being the original.<br>
the adrian wings are fbreglass ones.(i might be tempted)<br>
slant4..'You wull notice the door end, mor or less in the middle of what looks like one panel - one part belongs to the a-post - a light chisel after a careful grind' <br>
what looks like one panel is the bit causing me problems.!!.<br>
J.
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... 00dolly</A> at: 22/7/06 12:46 am<br></i>
Locked
Users browsing this forum: Google [Bot] and 0 guests
