Does anybody know the correct order of the washers on a Dolomite 1300 gearbox rear mounting. Does the very large washer live between the rubber mounting and the subframe ?<br>
Andy.
1300 Gearbox Mounting
dolomaddad
1300 mounting
Hi,if anyone can help in the meantime then fair enough,I will have a look at mine 2moro and update if req.
dolomaddad
1300 Mounting
Hi,have had a look today,the order is as follows:-<br>
Mounting<br>
Larger of the 2 washers<br>
Subframe<br>
Smaller washer<br>
Nut.<br>
Hope this helps,Dolomaddad.<br>
PS,can email you a photo if req,dont know how to add it onto here.
Mounting<br>
Subframe<br>
Smaller washer<br>
Nut.<br>
AndyThomas
Mounting
Thanks for your reply, that the order I thought they should be in but I was a bit confused by the need for a large washer / spacer under the mounting.<br>
Andy.
Andy.
dolomaddad
Glad to help.
No probs......<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <br>
dolomaddad.
dolomaddad.
