Intriguing waterpump problem....
Locked
alun n
#1 Post by alun n » Sun Jan 18, 2004 11:28 pm
.....either in ignorance or in his haste to strip all bits off the car I recently bought, the PO has sheared off the waterpump LH bolt at the shoulder well within the shaft itself so I can't easily weld something to it to facilitate removal.<br>
Any suggestions how to get it out? Do they make 'easy-outs' for LH threads? Don't particularly want to drill it out or weld to the shaft itself as otherwise the pump seems in good order. Can't weld to the impellar as its cast iron. Its a 12 vane so there is insufficient shoulder for mole grips or similar.<!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
george
l/h
#2 Post by george » Mon Jan 19, 2004 1:19 am
i'm sure i seen a left hand easy out set with snap on tools but i havent got a current or old book to check
SprintV8
Easy out's
#3 Post by SprintV8 » Mon Jan 19, 2004 1:27 am
Snap on do a Left Hand set,<br>
EXDL10 £52.05 inc Vat 5x Easyout's + 5xDrills<br>
Not sure if you can buy just the one you need,<br>
The normal Right hand set is EXD10 £35.37 inc Vat<br>
http://www.Snapon.com/uk/<br>
Or try a local enginnering Firm
SprintV8
Found Them
#4 Post by SprintV8 » Mon Jan 19, 2004 1:42 am
Sprial Extracter Screw EX-2 4-6mm £2.70 <br>
" " " EX-3 6-8mm £2.82<br>
" " " EX-4 8-10mm £3.17
Why use an easy out....
#5 Post by Jon Tilson » Mon Jan 19, 2004 9:31 am
Just drill and tap with an ordinary right hand threaded bolt. As you do it up you'll undo the remains of the pump bolt...<br>
Or you'll then have something to yank upwards with...<br>
alun n
Re: Why use an easy out....
#6 Post by alun n » Mon Jan 19, 2004 11:03 am
Jon; practical (and economic) as ever!! If it doesn't work then I can still use Phil's referencing and get the 'easy out'<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Thanks Guys
interesting use of English
#7 Post by Dave » Mon Jan 19, 2004 4:07 pm
implies alun must have considerably more patience than I have intriguing is not the word I would have used<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/im ... /smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
Locked
