1500 ROCKER OIL FEED RR1340
Locked
Barry Worrallo
#1 Post by Barry Worrallo » Sun Nov 02, 2003 9:50 pm
If you fit the above part from RIMMERS, and then also fit part nos. AEK113(<!--EZCODE EMOTICON START 8) --><img src=http://www.ezboard.com/intl/aenglish/im ... lasses.gif ALT="8)"><!--EZCODE EMOTICON END--> , to your valve stems, BEWARE as two of these rubber rings ended up in the sump, the remaining six were found in various parts of the head and engine block. THEY HAD ALL SPLIT!
Serve u right....
#2 Post by Jon Tilson » Mon Nov 03, 2003 10:51 am
The 1500 has absolutey no need of this bodge as long as its had regular quality oil changes. You want the high pressure oil in the crank bearings and not in some poxy external tube spraying oil over your block and over-loading the rocker cover gasket.<br>
Jod Clark
External Oil Feed
#3 Post by Jod Clark » Mon Nov 03, 2003 5:32 pm
There is no problem with the external rocker feed as long as you use the proper one, otherwise you can reduce the pressure to the bearings as Jonners mentioned and ALWAYS use a new compression washer if you ever need to remove the pipe.<br>
As for the little rubber rings that are supposed to cure oil-down-the-stems problems, if you are expecting a crappy o-ring to fix the problem then you are very very optimistic. Crap idea.<br>
Jod<br>
alun n
Re: External Oil Feed
#4 Post by alun n » Mon Nov 03, 2003 5:54 pm
Ford fit these as standard, the exhaust ones go brittle after a few miles and disintegrate. My mate pays his mortgage by replacing them; he thinks they are a great idea!<br>
The 2.5 Triumph engines (1500 plus 2) benefit greatly from the rocker feed kit, reduces that typically tappety noise they'd make otherwise.
Barry Worrallo
EXTERNAL OIL FEED
#5 Post by Barry Worrallo » Wed Nov 05, 2003 11:21 pm
Thanks lads for your comments. I now get the picture! Once bitten, twice shy!!!!!
Richard the old one
External oil feed
#6 Post by Richard the old one » Fri Nov 07, 2003 10:19 pm
I was thinking of fitting the external oil feed to one of my 1500s but after reading the comments I think I will stick with the original design.
Jod Clark
External Rocker Feed
#7 Post by Jod Clark » Fri Nov 07, 2003 11:53 pm
I have always used the external rocker feed and wouldn't use a 1500 engine without one. Not much money and eliminates the rocker shaft wear that these engines suffer. Recommended here...<br>
Jod
gerorge
tappets
#8 Post by gerorge » Sat Nov 08, 2003 12:35 am
when i used to work for a triumph main dealer we never had any problems with oil feed to rockers other than <br>
owners who did their own servicing not checking the <br>
screw on the rocker shaft at service intervals this did have a habit of working loose other than that they seemed to go for pretty high miles whith out too much wear and you could always get them to run quiet
Clive Wright
Valve stem oil seals
#9 Post by Clive Wright » Mon Mar 01, 2004 3:42 pm
These valve stem oil seals should only be fitted to engines with single springs...if your engine has twn springs as on the 1500 engine there is insufficient bore in the small spring to clear the OD of the seal !!
Locked
