pistons identity help
hello i was given a tr7 block with a new set of pistons inside trouble is i cannot identify them they have 2 indents for the valves and they measure 90mm across the face they have the following numbers on ID19 T49A +508 are these oversize? and by how much? thanks in advance.<!--EZCODE EMOTICON START :hat --><img src=http://www.ezboard.com/images/emoticons/pimp.gif ALT=":hat"><!--EZCODE EMOTICON END-->
Re: pistons identity help
sorry forgot to mention will these fit my spare sprint block? thanks.<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
Yer but are a lower compression. TR7s are 9.25 comp ratio and Sprints are 9.5. Both are 90.3 mm bore though and even the same stroke (78mm)
thanks for that info adam<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
I think the +508 is the metric equivelent of +0.020".
<p>Martin<br>
<p>Martin<br>
thanks mart<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Re: pistons
Ahh never though of it that way George! <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Re: comp
can anyone else confirm that the +508 is 20 thou oversize thanks<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
Re: comp
0.020" is exactly 0.508mm according to <!--EZCODE LINK START--><a href="http://www.megaconverter.com/mega2/" target="top">megaconverter</a><!--EZCODE LINK END-->. Not conclusive without a markings decoder for this piston manufacturer.<br>
Julian<br>
<p>1978 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/704">Dolomite Sprint</a><!--EZCODE LINK END--> Blue, a bit tetley.<br>
1980 <!--EZCODE LINK START--><a href="http://www.triumphowners.com/864">Dolomite 1500HL</a><!--EZCODE LINK END--> Orange, current daily drive.</p><i></i>
Julian<br>
Re: comp
thanks julian<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
Re: comp comparisons
TR7 Pistons <br>
UKC8519 Europe<br>
UKC1304 AUS/CDN/J/USA<br>
Sprint Pistons<br>
UKC0881 to VA1899E<br>
UKC2483 from VA1899E<br>
RTC2266 76 On<br>
you guys sure Sprint & TR7 Pistys are the same, Similar ?
UKC8519 Europe<br>
Sprint Pistons<br>
RTC2266 76 On<br>
pistons
strange as the very first tr we striped had sprint pistons and subsequent ones the same<br>
cant account for the part nos but as the tr7 is 8v<br>
then the pistons require no notches for valve clearance<br>
as the differance on the cr is only .25 this would be down to the head design piston height is identical dia is as well <br>
maybe a ploy from leyland to extract the max money from sprint owners ? jags used parts and the part nos were different for the identical thing for triumph<br>
if they were already producing sprint pistons then it would have been more cost efective to just adopt sprint pistons in what is a sprint block<br>
does seem strange though<br>
notice that the part nos changes in 76 does the tr7 do the same ?
Re: pistons
The '7 engines I have stripped have always had dished pistons, but I've only done three of them. I thought with the 'vertically paired' valves they needed the dish to prevent interference...<br>
Knowing of Pringle of old he did some strange things...
