1500HL Head gasket problems
Jod Clark
Re: Head Gasket
#16 Post by Jod Clark » Sun Feb 01, 2004 1:08 pm
I was unable to determine the manufacturer of the failed gasket, but it was unlike any other I have seen.<br>
I refitted the head with a Payen head set, but this contained a Coopers head gasket, a nicely made item similar to that I used when I built the lairy engine in my car.<br>
Incidentally, the head Payen head set was £35 inc VAT. How does that compare to the Robber Brother's price?<br>
Jod
Guest
Gaskets......
#17 Post by Guest » Sun Feb 01, 2004 3:33 pm
Give Engine line a call on 01928 573000 if your after gaskets(or any other bits) the Payen head set will prob set you back about £20-25 inc VAT and postage!<br>
Andy.<!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/im ... s/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END-->
AndyThomas
Head Gasket
#18 Post by AndyThomas » Wed Feb 04, 2004 7:58 pm
After fitting the Rimmers County head gasket to my toledo and reading this topic I have changed the head gasket to a Payen part (AK260) which is actually a Cooper gasket. The difference in quality between the two gaskets is very noticeable as is the fit. The price for the new gasket was only £11 including postage from Canley Classics.
Jod Clark
Re: Head Gasket
#19 Post by Jod Clark » Wed Feb 04, 2004 9:10 pm
Sounds like a wise move to me Andy! Was the Rimmer one a kind of dimpled affair?<br>
I know that the Coopers gasket is the one to have on the 1500, if it has survived my car for 22,000 miles with no problems it has to be good. I'm aware that it isn't too expensive on its own but I got the complete head set for Barry's motor as the work was done on a Sunday and I didn't want to tempt fate! Good value when you see what you get in the kit and superb fit too!<br>
Jod
C Mallock
1500 engine
#20 Post by C Mallock » Thu Feb 05, 2004 10:00 pm
What should a 1500 sound like? mine has a abrasive harshness too it. But had good oil pressure (80psi 3000rpm) uses no oil water pulls very strong. Im just a lil worried that it will let go when im miles from home, i believe the engine is quite fresh and having lifted the head off there is no bore wear and only gentle valve burning that was removed with grinding paste.<br>
Many thanks
Jod Clark
Re: 1500 engine
#21 Post by Jod Clark » Thu Feb 05, 2004 11:05 pm
A standard, unmodifed 1500 in good nick is should sound quiet and solid. They always tap a little from the top end but this should be a tap, not a rattle. Rattles that adjusting the tappets wont cure usually indicates a worn-out rocker shaft.<br>
1500s generally do rasp a little through the exhaust, especially later ones as the MG Midget / Spitfire / Dolomite all ended up using the same camshaft, although this is a little documented fact.<br>
A stainless steel exhaust system will make the exhaust note a little more lively.<br>
My 1500 on the other hand, sounds like something the devil would drive.<br>
Jod
C Mallock
reply
#22 Post by C Mallock » Fri Feb 06, 2004 12:52 am
Thanks for that, I will hopefully be building up a faster engine soon as i have access to belencing machines and a good deal with a engine machine shop, anything to look out for on this particular model?<br>
Im currently running a 2" free flow exhaust and open <br>
twin 1 1/2 SU with ram pipes. plays a nice tune and goes well.
Jod Clark
Re: reply
#23 Post by Jod Clark » Fri Feb 06, 2004 11:54 am
Get your machine shop to machine the main bearing cap to allow use of full-circle thrust washers. Use good quality main and big end bearings and use the best big end bolts you can find.<br>
Don't go wilder than a 285 - 290 cam or it will be a bugger to drive in town and will be continually fouling plugs.<br>
Don't rev it beyond 5,500 no matter what anyone tells you!<br>
And use a decent head gasket!<br>
John Skinner
Con Rod Bolts
#24 Post by John Skinner » Fri Feb 06, 2004 2:17 pm
Sierra/escort cosworth big end bolts are supposed to fit the 1500.
C Mallock
bolts
#25 Post by C Mallock » Fri Feb 06, 2004 7:23 pm
Thank you for that, im imagining the bolts are 3/8 so some arp or cosworth bolts will be an easy find,<br>
I must look into my current cam, i believe the car has always been owned by a elderly gent but i suspect there is something sub-standard in my engine as i can out run lots of modern stuff to an impressive speed and has a healthy exhaust and intake tone.<br>
Jod Clark
Re: bolts
#26 Post by Jod Clark » Sat Feb 07, 2004 10:06 am
Add an oil cooler and external rocker feed kit too. Personally I wouldn't bother lightening the flywheel. Use an electric fan instead of the normal windmill. Uprate to a Sprint radiator.<br>
Use lightened, tuftrided cam followers on your new camshaft and uprated valve springs without the lower collars. Fit a duplex timing chain set. Uprated the oil pressure relief valve.<br>
The will be a 1500 engine with all this work done appearing on eBay before too long.<br>
Jod
C Mallock
engine
#27 Post by C Mallock » Tue Feb 10, 2004 9:58 pm
The windmill is long gone! i was interested in putting a sprint or 1850 rad on but told that it would not fit, i have the materials and kit to make alu water pipes so if the bigger rad mounts up i will do so, Was hoping to find one at Stoneleigh last weekend but as my clutch went on the way that took a higher priority,
IRL1177NI
Faster 1500
#28 Post by IRL1177NI » Wed Feb 11, 2004 9:19 am
I have some new unused go-faster bits for the 1500.<br>
Mail me a tom(dot)lambe(at)heinz(dot)co(dot)uk if you're interested.
C Mallock
bits
#29 Post by C Mallock » Fri Feb 13, 2004 1:38 am
Having just done my clutch i have a lightend flywheel maybe there is more to my engine than i thought, it always has has a willingness to rev and pull me along at licence loosing speeds, now looking for a decent set of roller rockers,
Barry Worrallo
1500HL HEAD GASKET.(FIXED.!!!!!)
#30 Post by Barry Worrallo » Sat Feb 14, 2004 10:24 pm
Jod,<br>
Thanks for the pics of my blown head gasket, I now have photographic proof as well as the gasket itself.!....As to who fitted it, it may be "unprofessional" to "name names." It could also sound like "sour grapes" on my part. I think I should just put it down to experience, and try not to think about the money I wasted.! (What a WALLY.!!!!).<br>
Cheers,<br>
Barry.
Locked
Users browsing this forum: Semrush [Bot] and 0 guests
