Page 2 of 2
Re: progress report
Posted: Mon Aug 21, 2006 10:01 pm
by Nathan MWK 627G
ok popped round next door and the guy had some old imperial feeler guages, the points were well out so ajusted them accordingly and tried to fire...............she went but with a worse missfire than befor which did settle down!!...next was to check the Diaphragm.........."thats completly knackered" said my neighbour so got the spare put it on and she burst into life........<!--EZCODE BOLD START--><strong>NO MISSFIREING</strong><!--EZCODE BOLD END--> YIPPEEEEEEEEEEEEEEEEEEEEEEEEEE <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/images/emoticons/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>
shes still a little rough so a little clean around the connections etc..!! and a check of the fuel pump just to set my mind at piece but at the min shes running ok!! <br>
ill also do what Martin has advised and do a carb rebuild and also many other checks hes advise along with the rest of you!! <br>
Big thanks to all you guys, first time iv used the forum with a problem and you've all been very helpfull!! thanks again and hopefully see you at the TDCIR <!--EZCODE EMOTICON START :b --><img src=http://www.ezboard.com/images/emoticons/tongue.gif ALT=":b"><!--EZCODE EMOTICON END--> <br>
<!--EZCODE IMAGE START--><img src="http://im1.shutterfly.com/procserv/47b6 ... QZt3DZwzYo" style="border:0;"/><!--EZCODE IMAGE END--><br>
THE OFFENDING DIAPHRAGM<br>
THE HOLE CAUSING THE MISSFIRE
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... lub>Nathan MWK 627G</A> at: 21/8/06 10:03 pm<br></i>
Re: Well Done!
Posted: Mon Aug 21, 2006 10:16 pm
by mbellinger
Always good to have a positive outcome. The fact that you have a spare carb is even better as you can rebuild one at leisure.<br>
I know Jonners hates Strombergs, but all is fair in love and war and he is right about the diaphragms, especially with some of the crap quality replacements about.<br>
I now carry a spare in the glovebox - nuff said!<br>
Well worth doing the other checks and changes as methodically as you can. A good 1300 should rev willingly, and achieve a consistent 33 to 38 mpg, more on a run if gently driven.<br>
A good result though Nathan, and you know a bit more about your car now.....
<p>Martin<br>
1968 Triumph 1300FWD<br>
1975 Triumph 1500TC Auto<br>
1989 Honda Civic 1300 Auto<br>
2006 Mondeo 2.0 Ghia X Auto<br>
2002 Renault Scenic<br>
</p><i></i>
Re: Well Done!
Posted: Tue Aug 22, 2006 12:04 am
by Carsreunited
I have a spare CD150 if anyone wants to put their name on it I'll bring it to TDCIR.<br>
Re: Well Done!
Posted: Tue Aug 22, 2006 4:52 am
by Jod Clark
<!--EZCODE QUOTE START--><blockquote><strong><em>Quote:</em></strong><hr>There is one member of this forum who virtually stripped an engine before he realised he had an old piece of rag obstructing his air box.......<hr></blockquote><!--EZCODE QUOTE END--><!--EZCODE EMOTICON START :| --><img src=http://www.ezboard.com/images/emoticons/indifferent.gif ALT=":|"><!--EZCODE EMOTICON END--> <br>
I found a brand new diaphragm on top of my fridge the other day. I'll bring it to TDCIR and the first person to fall in love with it can have it.<br>
Jod
Re: Well Done!
Posted: Tue Aug 22, 2006 9:30 am
by alun n
You should get your ladies to tidy up after themselves Mate! Leaving it on top of the fridge? No use to man nor beast there!
Not one to crow...
Posted: Tue Aug 22, 2006 9:34 am
by Jon Tilson
but with a 'berg the diaphram is alwasy the first place to look if ignition is all good.<br>
I think the carb Ken will have donated of his 1300 is an SU. You can fit this and it will be an improvement but you will need to change the manifold too.<br>
Jonners<br>
