If you have some wire the 3 amp connectors for car hi fi speakers will fit the switch end - you may have to bend them a little to make sure they don't touch the inside of the knob.<br>
You could always come to Stoneleigh and avoid temptation to use the overdrive......<br>
I promise it wasn't me that used domestic electrical flex to wire the car up it was the owner previous to me; I got rid of a lot of it. <br>
Is the radio still wired in with a 30m orange lawn mower cable?<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Blown fuses - overdrive wiring short circuit
Re: Speak out!
Is that what that was for? I wasn't even sure it was connected to the car. I disconnected the overdrive switch completely, and wrapped the connectors at the bottom of the stick with insulating tape so I don't get a shock.
Richard the old one
Cable assembly for o/d
I have used normal domestic sheathed flexible two core cable on two of my cars as I consider that the sheath provides an additional layer of protection. <br>
You quite often know that you have a problem when you start to get shocks as you switch O/D out. This is because the magnetic field associated with the solenoid induces a high voltage in the wires as it collapses.<br>
Richard<br>
Richard<br>
Users browsing this forum: Google [Bot] and 1 guest
