Page 3 of 3
Re: Jon
Posted: Mon Mar 29, 2004 11:35 am
by Jod Clark
I think it was propshaft UJ needle-rollers being referred-to.<br>
Jod
Is there a kit
Posted: Mon Mar 29, 2004 12:31 pm
by AndyS
To replace the whole UJ/bearing setup?
Re: Is there a kit
Posted: Mon Mar 29, 2004 5:41 pm
by AndyS
well I've just ordered 2 UJ's from Rimmers to do the rear prop. Hopefully these will come with needle bearings and spiders etc.<br>
if this doesn't cure it, a large branch willl be taken to the car Basil stylee!
Re: Is there a kit
Posted: Mon Mar 29, 2004 9:49 pm
by alun n
There is no bearing on a Sprint layshaft, it runs direct in the case. If its this you will not get the noise in fourth.<br>
Disregard the gearbox as its a recon one! Why's that then? if it has only started since it went in then that is the first place I'd start looking!!<br>
seb had a "recon" engine don't forget!
Re: Is there a kit
Posted: Tue Mar 30, 2004 8:47 am
by AndyS
Alun,<br>
it started well before the new box went in. That was one of the reasons why we changed the box. Apart from thinking it might have been a bearing, the box needed an overhaul as it was leaking badly.<br>
I've ordered two UJ's for the prop(rear) as I believe when the needle bearings go, you get the same symptons........bad vibration and 'clunking' sounds. It could also be backlash at the diff but first thing first.
If it isnt....
Posted: Tue Mar 30, 2004 9:05 am
by Jon Tilson
the propshaft you could jack both rear wheels up, put on axle stands and run it in gear. That should help diagnose the problem.<br>
Re: If it isnt....
Posted: Tue Mar 30, 2004 9:09 am
by AndyS
Thats a very good idea Jon....should have done that first off! <!--EZCODE EMOTICON START :p --><img src=http://www.ezboard.com/intl/aenglish/im ... tongue.gif ALT=":p"><!--EZCODE EMOTICON END--> <br>
We'll get there in the end.
Re: If it isnt....
Posted: Sat Apr 10, 2004 4:05 pm
by AndyS
FOUND IT!<br>
looks like it was the rear prop shaft bearing. Changed them today, the most rear one was knackered!!! After all that!<br>
Thanks for your help all.
Ah!
Posted: Sat Apr 10, 2004 8:52 pm
by BDN712V
Good stuff! Think I'll check mine when I'm under it this week...<br>
Tim
