Investigating noises in the transmission
AndyS
#1 Post by AndyS » Wed Mar 24, 2004 9:56 am
Well, just got VCA back with the new gearbox and I STILL have the same intermittent tinny, clanking noise coming from underneath! <br>
Could it be any of the following:<br>
1. Wheel bearings<br>
2. prop<br>
3. Diff<br>
4. Suspension<br>
5. Air threshener<br>
As anybody had any problems with the above which might give the same symptons? It only happens in drive.<br>
HELP!
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 16/10/06 3:43 pm<br></i>
BDN712V
possibly??
#2 Post by BDN712V » Wed Mar 24, 2004 1:04 pm
The exhust bouncing around and clattering on bodywork?? Check your exhaust mounts. I'm probably wrong, but think that's the problem with mine after spending AGES trying to track it down.<br>
Tim
AndyS
Hmmmm
#3 Post by AndyS » Wed Mar 24, 2004 1:22 pm
Good point..... though the sound is more tinny and it only happens in drive. Surely there would be a dull 'phud' at standstill if the exhaust was 'bouncing'???<br>
I'll check anyroad.<br>
Just been examining the old box and there was oil oozing from every orrifice........ <!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/im ... s/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END-->
Worrying....
#4 Post by Jon Tilson » Wed Mar 24, 2004 2:50 pm
Did u take of the converter as u did the box?<br>
I'd have a look for scraping marks on the back of the converter thru the starter motor hole. A loose end plate bolt or converter bolt may be causing it.<br>
AndyS
No Jon
#5 Post by AndyS » Wed Mar 24, 2004 3:30 pm
I didn't actually do the work so I couldn't say. I'm sure the garage would have mentioned something of the sort if a bolt was loose.<br>
I also get the niose if I go over a bump too!
mcharlish
Re: No Jon
#6 Post by mcharlish » Wed Mar 24, 2004 3:56 pm
I think it's your exhaust somewhere in the vicinity of the gearbox or rear axle<br>
BDN712V
had another look
#7 Post by BDN712V » Wed Mar 24, 2004 4:41 pm
at mine, and reckon it could well be that. It is fine when just sitting there, but when you move off or go over rough roads (lot round here) it does bounce and clatter. Quick job to test the mounts.<br>
1) Check that you can still see them.<br>
2) Wiggle the back of the exhaust and see if it moves much / rattles about.<br>
3) Replace rubber mounts as required.<br>
If it isn't this, do let us know!!<br>
Tim
AndyS
Ok
#8 Post by AndyS » Wed Mar 24, 2004 4:58 pm
I have got a standard box on at the moment, so I'll do the checks and report.<br>
I hope it is this! <!--EZCODE EMOTICON START : --><img src=http://www.ezboard.com/intl/aenglish/im ... ohwell.gif ALT=":"><!--EZCODE EMOTICON END-->
george
clang
#9 Post by george » Wed Mar 24, 2004 6:10 pm
could be a loose baffle in the box ?
retro baz
Re: clang
#10 Post by retro baz » Wed Mar 24, 2004 7:16 pm
i get this problem while driving around at normal speeds but when i wheelspin i gets really bad.<br>
i found it was the exhaust hitting the diff so i would say, get the back end in the air and check how close they are on yours.<br>
a few of my mates had this problem in various cars (escorts, kadett and a viva) and all of these were down to the bracket being welded on in a diffrent place on the new exhausts.<br>
AndyS
Re: clang
#11 Post by AndyS » Wed Mar 24, 2004 7:58 pm
Y'know, thats exactly how it sounds like metal on spinning metal and it is a tinny, hollow sound.<br>
I'll have a good look around it tomorrow morning. I've checked all the mounts and tried to move the exhaust from the tailpipe. No sounds or abnormal movement;seems the rubbers are doing their job ok.
davejbaxter
rattle
#12 Post by davejbaxter » Wed Mar 24, 2004 8:34 pm
You mention metal on revolving metal ? While under the car check along prop shaft for brake pipes/fuel pipes coming adrift, also chock wheels and check handbrake cables arent flapping when handbrake is off. They are quite close to prop and just could be adrift and touching. I know its a long shot, but worth checking.<br>
AndyS
Re: rattle
#13 Post by AndyS » Wed Mar 24, 2004 9:47 pm
Cheers Dave,<br>
I'll check that out too!
retro baz
Re: rattle
#14 Post by retro baz » Wed Mar 24, 2004 10:15 pm
have u thought about the prop main bearing?<br>
i can remember reading about something like this before.<br>
that also could cause it....couldn't it???
alun n
Re: rattle
#15 Post by alun n » Wed Mar 24, 2004 11:58 pm
inner speedo cable worn.<br>
or it could be that electric gizmo you put on.....started about the same time!<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/im ... /laugh.gif ALT=":lol"><!--EZCODE EMOTICON END-->
Locked
