freudenberg damper
freudenberg damper
morning all, anyone know where I can get a Freudenburg crankshaft damper these days?<br>
regards brian
regards brian
damper
taking advice from a man in Birmingham who has built race and rally engines from mini thru dolly's and finally Toyota, for people like Tony Dron, Andy Rouse and Chris Hodgetts, if he says the only way to rev a dolly engine high is to use a crankshaft damper then I tend to believe him.
Re: damper
Depends why you want to rev it high?<br>
A well built & balanced road engine with uprated valve springs should happily rev to 7000rpm but if you want to go mad and have an 8500rpm race engine the normal stuff wont last long.
Stephen Grellet
Freudenberg Damper
I tend to think the Freudenberg damper was used to offset the weight of the standard flywheel which had to be used in Group 1 racing. Because you can now use a lightweight flywheel I dont think that they are as necessary. I use a lightweight steel flywheel and run no damper on the front at all and normally run to 7500 rpm. with no apparent problems (so far)
Neil Russell
Dampers
Question.<br>
If you buy a damper which has not been supplied with your engine, how do you know that it has the correct out of balance to counteract the flywheel and internal reciprocating thrust??<br>
Neil.
Neil.
Stephen Grellet
Dampers
The front pulley/damper is dynamically balanced when new. You may find balance holes / drillings in the outer hub. Also the flywheel will be within certain balance standards from the factory as will the crankshaft.
Neil Russell
sarcasm, Sorry.
I was picking up on your earlier thread Simon. I think people tend to look and talk about the purchase of items they do not fully understand, because someone has said that the item in question will make an engine rev better etc etc.<br>
Engine building is an art form. and you decide what the engine is to do at the outset so you can build the engine with the best torque spread / rev limit for the purpose.<br>
A Harmonic crank damper works with the principle of fluid dynamics at is core. the actual bit of kit Counteracts the harmonic vibrations which can result from torsional shock produced during the rotation of a crank. It is not fitted as an alternative to balancing. The trouble is that many armchair engine builders think that a balancing job is where a man in a machine shop spins a rotating mass of crank, rods, pistons and flywheel and drills holes to correct out of tolerance.<br>
balancing when done properly takes a long time, starting with pistons, then rods, end to end , then rotating assembly. If a flywheel has been lightened previousy has it been done correctly? different engines have different degrees of out of balance for example. The ford V8 small block has two types of flywheel both with different out of balance wheightings. If a flywheel has therefore been lightened has the correct out of balance been restored during machining.<br>
Harmonic crank dampers are actually out of balance when supplied due to the principles in which they work. If a correctly built engine has been put together then as you said earlier, they are simply not needed. In my experience they are mainly used when internal balancing cannot be fully achieved, due to bore tolerances, crank design etc etc. If used on a correctly built engine they will prolong crank life because they smooth things out further, we are however definitely not talking dolomite engines ?? More like exotics. Our friend who has been advised that they will increase his rev limit is mistaken, especially if he has not built his engine paying full attention to the internals standing up to the pounding.<br>
I cannot ever remember a 16v dolomite engine lunching its crank before the valves disintegrated??<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>
Neil Russell<br>
Neil Russell.
Neil Russell<br>
Neil Russell.
Mike Groom
Re: freudenberg damper
Have a look in-<br>
<!--EZCODE AUTOLINK START--><a href="http://www.freudenberg-nok.com/static_n ... <!--EZCODE AUTOLINK END--><br>
this has details of a US supplier, if you REALLY want one!
"..I think people tend to look and talk about the purchase of items they do not fully understand..."<br>
good description of me and Dolomites generally....<!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/im ... s/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> <br>
I take it you've had experience of building high output engines Neil ?<br>
How's the Russett Auto coming on, BTW ?
Neil Russell
Engines and Dollies
A couple.<br>
I have a fetish for the narrow angle small block ford V8 which I used to play with from time to time.<br>
Why dont you see yhe dolly, we can work out a completed on the road price, and I will finish to your budget?? i will be looking for £1300 finished with MOT and new tyres??<br>
Neil.
Neil.
harmonics
IIRC I read somewhere about there being a destructive harmonic that the freundenberg damper removed. (8,200 rpm?) I also read somewhere about Andy Rouse having a comprehensive engine blowup which involved part of the engine clearing a stand! anyone else remeber this ? it was in classic car I think?
Stephen Grellet
Balancing
Balancing a four cylinder inline engine is a straight forward job. It is when you come to vee engines that problems can occur as some of these engines are balanced externally, ie weight added to a certain part of the fly wheel or crank damper. As far as I am aware four cylinder motors are all internally balanced <br>
(counterweights on the crankshaft) and pistons and rods match weighed/ end for end etc. Re engine blow up I think it was Tony Dron, who had overdrive electrical failure during the race with the o/drive dropping out a few times and the engine over revving that caused it.
Users browsing this forum: No registered users and 4 guests
