Boo!
Locked
SMIFTER
Boo!
#1 Post by SMIFTER » Tue Jul 26, 2005 8:51 pm
Just thought it was getting a bit dull lately and see if anyone was still awake??<br>
<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
<p><!--EZCODE LINK START--><a href="http://www.smifter1971.pwp.blueyonder.c ... >Smifter's Dolomite Sprint Website</a><!--EZCODE LINK END--><br>
1974 Soon to be non Triumph powered Dolomite Sprint to scare myself senseless.<br>
2004 Smart Roadster 80BHP to laugh myself senseless<br>
1997 Audi A4 2.6 to bore myself senseless.</p><i></i>
MaddMart
Re: Boo!
#2 Post by MaddMart » Tue Jul 26, 2005 9:16 pm
Yep, I'm usually watching.<br>
So you're up for Keevil on the 22nd August. I'm going to book my place by the end of the week.<br>
Will also be doing the Combe on the 10th September...all being well.<br>
Martin
<p><!--EZCODE LINK START--><a href="http://www.dolomitesprint.com/" target="top">www.dolomitesprint.com</a><!--EZCODE LINK END--></p><i></i>
bodgerben
Git!
#3 Post by bodgerben » Tue Jul 26, 2005 9:43 pm
Go and wake someone else up!<br>
Ben<br>
(I'm not up for any track action this year, mind you just got a lovely 1972 2 door Toledo - Sprint conversion - oh Yes <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/im ... /happy.gif ALT=":D"><!--EZCODE EMOTICON END--> )<br>
<!--EZCODE LINK START--><a href="http://www.dollysprint.com" target="top">www.dollysprint.com</a><!--EZCODE LINK END-->
KLJ895W
Re: Git!
#4 Post by KLJ895W » Wed Jul 27, 2005 10:46 am
How's the XE engine conversion coming on Smifter? Just got myself a Manta 5 speed box off good old ebay. Just need an engine to go in front of it now. It'll be interesting to hear how you put it all together. Are you mounting the engine off the subframe? What are you doing for fuel and ignition?<br>
David
<p>1980 Sprint<br>
1980 1850HL with Sprint gearbox, propshaft and axle<br>
1972 VW Camper Van</p><i></i>
SMIFTER
Re: Git!
#5 Post by SMIFTER » Wed Jul 27, 2005 1:51 pm
If your XE'ing it try and get an early engine has these have nice bits like forged pistons, cosworth cast heads and light flywheels. <br>
I've gathered all the bits together for the conversion but probably wont get round to starting work properly until october.<br>
I want to mount the engine as far back in the engine bay as possible. I order to do this I've got a shallow steel big wing sump and I'm chopping up an escort cross member to mount the engine from using XE/escort mounts. Its either the shallow sump or dry sumping which is beyond my budget.<br>
I've measured it up and I reckon It'll be better to mount the engine direct to the chassis rather than use the Sprint subframe unless you want the weight all over the front wheels like a Sprint is normally.<br>
For exhausts I've got a 4-2-1 2.25" outlet large bore RWD tubular manifold from Yukspeed. due to the space restrictions the passenger side floor of the car or the rear of the subframe may need modifying to suit<br>
For fuel and ignition I'll be dumping the standard XE set up which is too restrictive and using megasquirt'n'edis engine management fuellng through Yamaha R1 throttle bodies and a small dose of Nitrous. I plan to fit an innovate wideband Lambda sensor into the system so i can accurately tune it myself.<br>
The cheapest way of fuel and ignition is get a non injected 1.6 chavalier dizzy and run 45's but I fancy going more high tech! Plus the dizzy would hit the bulkhead.<br>
I take it you've got a Manta 1.8 getrag gearbox - GTE boxes wont fit. You'll also need a manta prop to join to a Sprint prop and either a 1.8 manta clutch assembly or use an XE clutch cover with a calibra turbo clutch plate. You'll also need to get a spigot bearing to fit in the flywheel end of the crank - they cost a tenner from Yukspeed.<br>
Cooling is using a Honda Civic Type R rad, I keep meaning to post a pic of it as it fits very snugly between the chassis rails.<br>
Its not going to be too easy but thats half the fun<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/im ... s/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
KLJ895W
Re: gearbox
#6 Post by KLJ895W » Wed Jul 27, 2005 4:52 pm
Oh dear! (or words to that effect) I've got a GTE gearbox. Good job it didn't cost me anything except £20 petrol to go and get it. Why won't it fit?<br>
I was only thinking of mounting to the subframe so that the car could be returned to standard later, but without seeing how it lines up in the engine bay I have no idea whether this is feasible. The distributor hitting the bulkhead is well known. I've assembled a Megajolt system which I could use with carbs, or do a megasquirt with throttle bodies.<br>
How much was the exhaust manifold? Is it mild steel? Any pictures? Cheers,<br>
David
<p>1980 Sprint<br>
SMIFTER
Re: gearbox
#7 Post by SMIFTER » Wed Jul 27, 2005 5:18 pm
Manifold was £160 and is mild steel<br>
Although its the same internals The GTE box only fits the opel CIH engines, not the later OHC engines - its a totally different bolt pattern.
1997 Audi A4 2.6 to bore myself senseless.</p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... SMIFTER</A> at: 27/7/05 11:10 pm<br></i>
Locked
Users browsing this forum: Bing [Bot] and 1 guest
