hey how would you go about shorterning the stroke of the piston (travel)<br>
jonny
shortening the stroke
Re: shortening the stroke
You'd need a crankshaft with a shorter offset between main bearings and big end bearings. You'd also need taller pistons so that the crown reaches the original point in the bore in order to maintain a usable compression ratio.<br>
Tinweevil
1972 Spitfire IV<br>
39 anorak points on the Nicholas scale<br>
</p><i></i>
Tinweevil
</p><i></i>
Ha! When I thought about this question for some reason you needed to bring the head to the pistons by making the block smaller not bring the pistons to the head by making them bigger <!--EZCODE EMOTICON START :rollin --><img src=http://www.ezboard.com/intl/aenglish/im ... s/roll.gif ALT=":rollin"><!--EZCODE EMOTICON END--> <br>
Adam
Adam
1st question Why?.<br>
Forged crankshaft with shorter stroke with con rod's to suit,<br>
And then forged piston's if your going to all that expensive.<br>
<p>1980 Dolomite Sprint V8 (They laugh at me because I am different. I laugh at them because they are all the same!)<br>
1997 Vauxhall Calibra 2.0 16v SE8<br>
2003 Suzuki GSX1300R (http://www.SuzukiHayabusa.co.uk http://www.UKbusas.org)<br>
Ronnie Barker A Legend.</p><i></i>
