Scott, how did you get on with your car. Did you overcome the problems you were having with it.<br>
Grelley
Scott
Carsreunited
Re: Scott
I did thanks. Should I know who you are? Did I meet you at Rockingham?<br>
Problems
No I'm in New Zealand. I responded to your query when you were having problems with run bearings. It is always nice to know the outcome of these problems and what caused this. This amy be of some use to other Sprint racers.<br>
Regds
Regds
Carsreunited
Re: Problems
Sorry. Didn't realise who you are. Stephen Grellet is it?<br>
No run bearings since last year. Sump was modified, rpm's brought down to a a realistic level for a non-crank damped engine. Had a few other probs since then but not engine related. I am now running an STR91 as my engine doesn't rev high enough to make use of a peakier cam. Haven't raced much this year 2 out of 3 were finishes so that's a big improvement!<br>
Regards,<br>
Scott
Regards,<br>
Scott
Users browsing this forum: Semrush [Bot] and 1 guest
