Steering column through bulkhead - WASHERS ???
Locked
JeanClaude
#1 Post by JeanClaude » Wed Dec 22, 2004 9:37 pm
Hello,<br>
I just wanted to change the lower steering column bush, but I had to take the complete column apart to get her of the car because the knuckle joint in the engine bay was impossible to get of the column shaft. <!--EZCODE EMOTICON START >: --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/mad.gif ALT=">:"><!--EZCODE EMOTICON END--> <br>
Now I read in my manual that there should be a plastic washer inside the car and a metal washer in the engine bay ... <br>
My steering shaft has a thick bend washer welded onto it IN the car and no other washer ?????????<br>
Also the metal plate witch bolts to the bulkhead is bend.<br>
Can anybody tell me if the thick washer is originally welded on the shaft, and if the metal plate is originally bend.<br>
See also my pictures on the Triumphowners site.<br>
http://www.triumphowners.com/519<br>
Many thanks.<br>
Jean-Claude
Locked
Users browsing this forum: Bing [Bot] and 1 guest
