I removed the bottom ball joint to replace the gaitor. Got if off no problem - used a pry bar to get the lower wishbone arm out, replaced the gaitor, no problem 30 mins in. <br>
But for the life of me I can pry the lower wish bone arm down low enough to get the ball joint connected in <br>
. What should I do - loosen the arm which connects to the lower wishbone to relieve some of the pressure?<br>
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 20/5/05 12:35 pm<br></i>
How do I get it back together? [balljoint replacement]
Users browsing this forum: Semrush [Bot] and 1 guest
