Front Lower Wishbones
Locked
Kehoemj
#1 Post by Kehoemj » Sun Dec 04, 2005 12:38 pm
How do I remove the lower wishbone from the steering arm? Removed the nut securing the two parts together, but still not clear how the wishbone comes off. <br>
Haines manual refers to a balljoint seperator & thrust pad to do the job.
gmsclassics
Re: Front Lower Wishbones
#2 Post by gmsclassics » Mon Dec 05, 2005 9:29 am
There really is no way other than to buy or borrow a ball joint separator - they aren't expensive and you'll need one everytime you need to split a ball joint on the steering / suspension. The ball joint is a taper fit in the arm and will not come out without the sort of force that can be applied by the separator. <br>
Geoff
Things to consider...
#3 Post by Jon Tilson » Mon Dec 05, 2005 10:45 am
There are 2 types of seperator. One is a forked wedge that you bash in with a hammer. Crude, cheap effective and almost always destroys the ball joint rubber boot.<br>
If the existing ball joint is good...no play and a decent boot then its worth getting the more expensive screw action type. Not cheap but worth having both in my opinion...<br>
If its all off the car a hydraulic press will also do the job.<br>
Jonners<br>
Kehoemj
Wishbones
#4 Post by Kehoemj » Mon Dec 05, 2005 6:14 pm
Daft question. Is there a technique for replacing the wishbone?<br>
Assuming that I whack it with a hammer, wondered if that was wise.
Locked
