I refurbed by fuel tank a year or so ago and ever since have suffered from muck in the fuel lines. I fitted a cheapy filter between the line and the fuel pump cos it's easier than taking the pump apart all the time. I have been doing a bit of driving recently and when accelerating to cruise it will be fine then a 1/4 mile or so will start to splutter a bit. Having checked the fuel filter it seems to be OK so can only assume that the fuel line has got some muck in it further down thus redicung the flow of fuel. I have in the past used a foot pump to blow the fuel line throgh but the problem persists. Has anyone ever come accross a fuel line cleaner product that works or would I be better off just removing the tank again, flushing it out and blowing the line through until it is clear. I have also thought it might be a sticky needle valve in the float chamber causing overflow but it is difficult to see whether it is overflowing when running along!<br>
Incidentially the fuel tank restorer product in question was the POR-15 kit from Frosts so would be interested to know if anyone else has had similar experiences with it.<br>
<p>Mark<br>
1980 Dolomite Sprint<br>
2002 Ford Focus (just to be original)</p><i></i>
C**P in fuel lines?
dollysteve
Re: C**P in fuel lines?
Are you sure the fuel pump is up to the job, had very similar symptoms to this on the 1300 fwd, it transpired that the diaphragm had a pin hole in it, which only presented itself as a sump full of petrol.
<p>1976 Dolomite 1850 HL Auto<br>
1979 Dolomite 1850 HL Man o/d<br>
1989 Noisy Mini 1340 <br>
1994 VW Golf GTI</p><i></i>
SprintMWU773V
pump
The pump was replaced recently as the old sealed type was full of muck. Seems to be pumping well with no sighns of holes in the diapragm.
Re: C##p in the fuel line's
How often do you have to do that then?.<br>
Still say the oldies are Best.
<p>1980 Dolomite Sprint V8 (Sprint's where never meant to sound this good?)<br>
1997 Vauxhall Calibra 2.0 16v SE8<br>
2003 Suzuki GSX1300R (The Yamaha R1 is indicating 190mph When the Busa flies past)<br>
This space is available for advertising, contact user for rates.</p><i></i>
