Hiya,<br>
Can anyone help, with advice required to replace centre bearing carrier.<br>
Have removed propshaft and suspect centre bearing carrier worn, any ideas on how to replace this.<br>
My prop has 2 UJ's one at each end, diff and g.box and also the sliding centre joint.<br>
Any info appreciated. many thanks
Sprint propshaft
Re: Sprint propshaft
You have to 'uncripmp' the metal band around the centre CV, carefully cos you need to re-use it. then split the prop by dismantling the CV, replace the carrier and re-assemble. Don't kancker the CV coes they are not available (neither are the bits for them). A past issue of Dolly Mixture has covered the 'how to do'.<br>
Recent editions ahve covered the conversion to a Ford CV joint and new prop, Dave Mac props in Coventry are the folks to see <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END-->
