headlights dipped and main
Locked
rpgrainger
#1 Post by rpgrainger » Fri Aug 18, 2006 9:02 pm
Hi<br>
my headlights are ok on dipped and when i flash them all 4 come on.....but if i push the stalk forward the offside both lights stay on and the nearside only the main beam is on...which is correct and what could be the problem....<br>
Cheers<br>
Rob<br>
also just a quick one what size wheel nuts does my 1850 have, its a bit of an oddball as its on a 78 plate but has all black badges...need to know so i can get some wheel nuts to fit me sprint wheels
alun n
Re: headlights dipped and main
#2 Post by alun n » Fri Aug 18, 2006 11:59 pm
All 1850s had 3/8" nuts.<br>
All four should be on. Try another sealed beam unit first, could be half the double filament has gone
You have...
#3 Post by Jon Tilson » Sat Aug 19, 2006 11:47 am
a failed main beam filament in your n/s headlight I suspect.<br>
Flash puts them all on...<br>
but main beam uses the main beam filament only..<br>
Locked
