Engine Bay Wiring Lead route
Locked
Howie
#1 Post by Howie » Thu Aug 17, 2006 11:12 am
In the absence of any pictures to refer to, can anyone tell me where the live battery lead that goes to the starter moter is routed on a sprint. Is it along the front of the subframe or the back of the subframe and also are the wires from the main loom routed alongside it?<br>
Thanks in advance<br>
Howard
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... omiteuk</A> at: 30/10/06 10:04 am<br></i>
Back and yes
#2 Post by Jon Tilson » Thu Aug 17, 2006 11:49 am
Its all clipped together and the clips sit in mounting holes on the sub frame...then it bends round and heads for the starter...main feed, solenoid live and ballast feed.<br>
Howie
Back and Yes
#3 Post by Howie » Thu Aug 17, 2006 12:10 pm
Thanks Jonners, much appreciated.<!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END-->
alun n
Re: Back and Yes
#4 Post by alun n » Thu Aug 17, 2006 2:39 pm
surely, its the front of the subframe?
Just to clarify...
#5 Post by Jon Tilson » Thu Aug 17, 2006 3:29 pm
its the front of the subframe but the back side of it...<br>
The front of the front is under the valance...and you can see the wires wouldnt go that way...<br>
its obvious when you look at it from underneath.<br>
Jonners<br>
Locked
