water pump - sprint
water pump - sprint
Do I replace<br>
Do I refurb<br>
Do I leave it and hope for the best.<br>
I'm about to drop the engine back in not sure what to dthero about the pump. When it came out it left it's cage behind, all back together and cleaned - no play etc.<br>
Rather short of cash having given too much of it to rimmers.<br>
Seb
Do I refurb<br>
Seb
Re: water pump - sprint
1. Check the u/s impellar has a flat mating surface<br>
2. For the sake of the cost of a repair kit......use one! About £20 from Fitchetts
I agree with Alun....
ist a right PITA to cure the leak after youve got it running. If its all out fit a new repair kit. Robsport are an alternative supplier and your local machine shop should be able to flatten the underside of the impellor if its scored. New bearing and its good as new...almost.<br>
Re: Pump Tool
I have an easily made homemade tool comprising a large washer with three holes and an exhaust clamp which does the job, but if it came out once easily without further use it should do so again. Suck it and see....<br>
I'll take a picture of my tool and email it to you.<br>
Er...that reads badly and I can't think how to rewrite it without similar innuendo!
Water Pump - recon £45
Robsport do a recon for £45 quid - have just ordered one, will report on quality.<br>
pics of tools (metal) can be mailed to sebking@freeuk.com.<br>
Seb<br>
HWK36V
Seb<br>
HWK36V
Re: Water Pump - recon £45
Well yes, there are two nuts on the underside fairly close together, but the rod has been bent double to fit into both holes at the same time<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/im ... ns/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br>
I'll take a snapshot of it later
Robsport
£45 + VAT + 30 exchange<br>
Ordered on Tuesday, arrived Wednesday, Installed Wednesday evening and old unit postedon Thursday.<br>
Pretty good service from robsport and at £45 quid pretty good value I reckon.<br>
Seb
Seb
Very reasonable compared to the asking price for new ones. Never heard a bad word said against these guys.....<br>
Not a bad rate, £25, for fitting a £20 repair kit (that they get at cost!) either though......
