How do I identify my engines?
Locked
classic265
#1 Post by classic265 » Fri Aug 04, 2006 6:41 am
Greetings from New Zealand!<br>
As a pom over here, I had to have a UK car and have bought a Dolomite. It is an 1850, but the engine is cooked.<br>
It comes with three spare engines that I think are either 1300cc or 1500cc; definately not the same as the 1850, how do I identify what I have? Thanks, Ian. <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END-->
Carsreunited
Re: How do I identify my engines?
#2 Post by Carsreunited » Fri Aug 04, 2006 8:40 am
Welcome to the board!<br>
Try<br>
<!--EZCODE LINK START--><a href="http://club.triumph.org.uk/prefix1.htm# ... <!--EZCODE LINK END--><br>
Basically find the engine number and see what the prefix is.<br>
Cheers,<br>
Scott<br>
Welcome...
#3 Post by Jon Tilson » Fri Aug 04, 2006 8:49 am
to the asylum...<br>
Good choice...<br>
The 1850 engone is overhead cam with a chain drive, alloy head, cast iron block and canted over to the side. The 1300 and 1500 ohv are very similar to each other but totally different to the 1850, being enitirely cast iron and sit vertically.<br>
You should source another 1850 or TR7 engine for your car. Plenty here of course but not sure about over there...<br>
We do have other NZ correspondants so lets hope they can help you.<br>
tinweevil
#4 Post by tinweevil » Fri Aug 04, 2006 8:53 am
1300 and 1500 are a lot smaller and sit upright, the numbers stamped in the head would identify which you have. <!--EZCODE LINK START--><a href="http://www.teglerizer.com/triumphstuff/spitheads.htm" target="top">More info here</a><!--EZCODE LINK END-->.<br>
1850, TR7 and Sprint engines are all slant 4, i.e the head is well offset to the left side and the pistons travel at 45 degrees to the vertical. A Sprint has a broad rocker cover with Triumph cast into it and the plugs in tubes through the rocker cover. On 1850 and TR7 the plugs are over the exhaust manifold, 1 + 2 and 3 + 4 point at each other. These two can be hard to tell apart but a 7 lump should have a water outlet from the back of the head, the same spot on an 1850 is a blanking plate.<br>
Can you post pictures?<br>
Tinweevil<br>
classic265
#5 Post by classic265 » Sun Aug 06, 2006 7:14 am
Hi, thanks for all the info, have id all the spare engines as 1500's and have put up another post for some advice about which engine to use. Cheers, Ian.<br>
gmsclassics
Is this the light blue car that was on Trademe?
#6 Post by gmsclassics » Wed Aug 09, 2006 11:35 am
If it is, I know a bit of the history as I saw this in Rotorua about a year ago when it was previously sold. I'm in Auckland, have a few Dolomites and a TR7. Also know a few contacts locally who may know a bit about the 1500 motors. Give me a ring sometime at work 520 9502. Geoff<br>
PS There was a TR7 engine for sale on Trademe recently for $100 (in Hamilton I think). This would be ideal for the Dolomite and bolts straight in. Auction has finished and I don't know whether it sold so might be worth keeping an eye open. I have an old 1850 around in the shed but it was a bit rattly which is why we replaced it in my son's car.
<p></p><i>Edited by: <A HREF=http://p206.ezboard.com/bthetriumphdolo ... lassics</A> at: 9/8/06 11:45 am<br></i>
algtj
Re: Is this the light blue car that was on Trademe?
#7 Post by algtj » Wed Aug 09, 2006 12:10 pm
Unfortunately the 1500 won't bolt in to your 1500. The subframe is different.
classic265
Re: Engines and other bitz
#8 Post by classic265 » Thu Aug 10, 2006 12:24 am
Hi, this site is great, have found out lots!<br>
When I bought the car, it came with a hugh amount of spares, 4 1500 engines, overdrive gearbox, 1500 rear axle and complete 1500 front subframe and suspension, doors, screens, dashboard, seats, brakes and servo's and boxes of little bits I haven't made my way through yet!<br>
I have a choice therefore of finding an 1850 to replace and keeping the autobox (good for Auckland!) or stripping out and fitting a 1500 with manual box.<br>
So I have asked for opinions. Cheers, Ian.
classic265
#9 Post by classic265 » Thu Aug 10, 2006 12:29 am
Hi, yes this is the Rotorua/Auckland Dolomite! Will give you a ring. Cheers, Ian.
2F45T4U
#10 Post by 2F45T4U » Thu Aug 10, 2006 12:30 am
was the 1500 even sold abroad?
classic265
#11 Post by classic265 » Thu Aug 10, 2006 12:37 am
Hi, yes they were, the previous owner of my Dolly, broke three 1500's, hence all the spares. Unfortunately, for all the boxes of spares, he didn't keep a clutch pedal and assembly! Cheers, Ian.
Locked
