VYK The Russet 78 Sprint
dollyman
TDC Cheshire Area Organiser
Re: VYK The Russet 78 Sprint
#151 Post by dollyman »
That look's really nice Bish :D And those carpets have settled down a treat, much better than i thought they would 8) If you are planning on "cutting" the paint before waxing try and find some Farecla G3 compound, it works fast and it's easy to do.
A credit to you Bish.
Reg
#152 Post by Reg »
Great work Bish..looks great! 8) Thanks for the photo's.
Bish
#153 Post by Bish »
new to this wrote: Thu Jun 04, 2020 11:04 pm Bish
looking good ,thought you mite have tiried stainless steel wheel nuts
Nah, you know I’m too tight to buy stainless nuts when I can get 20 plastic caps for £6! :D
new to this
#154 Post by new to this »
Bish wrote: Fri Jun 05, 2020 10:12 pm
Bish
#155 Post by Bish »
Thanks Tony and Reg for the kind words. And, thanks both for your advice now and in the past, it’s appreciated :thumbsup:
Bish
#156 Post by Bish »
This weekend I’ve been struggling with the column switch for horn / indicators and main beam. I found a good tip on the forum which is to take the large multi connector off of the loom, tie string to said loom and pull it through the steering column. This leaves string to tie your new column switch loom to and pull it back through. Worked a treat, shame the switch didnt cure my problem though! I have funky things going on with my lights. Main beam wasn’t working at all, hence I changed the column switch. Now I have all lights on as soon as I switch ignition on!! Must be the master switch??
I gave up with electrics as they are obviously not my thing! Cracked on with the solid carb mounts instead, in the hope that they will help the car to idle and run smoother.
The old mounts were definitely shot.
Nice new solid mounts from the club.
I had a quick go at tuning up, and VYK seems to run smoother. I still think there maybe deeper issues though. We will see when I can get out on the road.
I’m at the point where it’s one step forward two steps back, I think I need to walk away from it for a week or two. Come back refreshed for another attack :D
Bish
#157 Post by Bish »
I’m on the final push before road worthiness!
Last couple of snags- ( for now )
I’ve re wired the headlight relays the right way this time! I now have headlights that switch on, and off!!
I’ve tuned VYK up and he’s running sweet now that the solid carb mounts are on. The timing is spot on with the tiniest bit of timing scatter - which may be down to a rather wobbly rotor arm? VYK seems to be happier than ever sitting on idle around 800 rpm, and pick up is smooth, I’m hopeful he’s gonna run well.
Horns don’t work even when whacked with a hammer.
No fuel light or gauge which when investigated turned out to be a broken sender.
Oil light is playing up which I hope is a duff switch!?
Exhaust down pipe is touching the subframe. I hope to shim the gearbox up a bit on the Volvo mount to counter act this, fingers crossed, plus replace the bushes and adjust the engine stabiliser bar.
So another shopping list of parts to fit this weekend - rotor arm, horns, Bosch red coil, oil pressure switch, fuel sender, stabiliser bar bushes, and some thick washers between gearbox and mount.
Then 🤞 finders crossed for a road test and mot time!
RSi
#158 Post by RSi »
Light at the end of the tunnel now, great feeling eh :thumbsup: I hope I'm not for behind you.
I'm at the cleaning stage, the engine bay and underneath, mucky job... but i love cleaning :lol: :lol:
Club Membership No: 2017092
Bish
#159 Post by Bish »
RSi wrote: Fri Jun 26, 2020 7:52 pm Light at the end of the tunnel now, great feeling eh :thumbsup: I hope I'm not for behind you.
You must love cleaning Murdo that’s for certain! Your cars looking stunning, and your attention to detail really is something. I take it you will only use your car on the sunniest of days? I wouldn’t blame you if that’s the case! I’m hoping to use mine as much as possible but not when the roads are salted. [-X
I hope we both get to use and enjoy them soon. :thumbsup:
dollyman
#160 Post by dollyman »
[/quote]
You are wrong i'm afraid Bish..... Murdo will only be taking his car out when the roads are covered in mud and salt :shock: :shock:
Just so he has an excuse to start the whole process of cleaning it again :lol: :lol: :lol: I'm not the slightest bit jealous of how clean his car is :wary: Much.....
RSi
#161 Post by RSi »
:lol: :lol: :lol:
Bish
#162 Post by Bish »
Good result today with the shims between the gearbox and the mount. I now have 7mm clearance between exhaust downpipe and subframe. It was a bit of a squash and squeeze under the car on axle stands again. I must learn to do the job properly the first time!
Overdrive sump gasket is leaking which is a bit disappointing as I renewed it when the gearbox was out. Is there a trick to getting the gasket to seal properly? I was careful to not overtighten the nuts around the sump plate. I remember that the gasket was a bit thin. Is there a better quality gasket available than the one I used I wonder?
Stabiliser bar bushes are on too, adjusted it up and it now seems a lot more solid.
Getting closer.......... :D
shaunroche
#163 Post by shaunroche »
[/quote=RSi post_id=331183 time=1593297374 user_id=15093]
[/quote]
[/quote]
:lol: :lol: :lol:
[/quote]
Hello Gentlemen, a bit off topic, but just to be correct, you need to remove the forward slash from the first [/quote] you only need that / at the end.......I apologise for the pedantry but I'm a Mechanical Engineer.....
RSi wrote: Sat Jun 27, 2020 11:36 pm
:lol: :lol: :lol:
Just trying to be helpful :roll:
In other news, loving this thread, think Chestnut is a very underrated colour. :)
RSi
#164 Post by RSi »
Bish wrote: Fri Jun 26, 2020 9:17 pm
Thanks Bish. Yes, it'll be dry use only.
Looking forward to it, as I'm sure you are too.
Bish
#165 Post by Bish »
Thanks, me too!
Maybe I like it because I was born in 1970 - the time when it was all the rage to pair brown and orange together! I love all those retro colours now, reminds me of my youth I guess?
When i was looking to buy a sprint I wasn’t going to be too fussy on colour. They are all good colours to my eyes because they reflect that period in time perfectly. :thumbsup:
