While you could get one made up relatively easily - someone/ blacksmith who can repair cart springs should be able to do it easily - problem will be mounting to the front of the subframe.
Mine came secondhand from a crashed racecar and had rose jointed adjusters plus purpose made alloy fixings to the subframe. Worked extremely well. Geoff
Sprint Suspension Set Up
- gmsclassics
Re: Sprint Suspension Set Up
- DSCN0090A.JPG (63.81 KiB) Viewed 5867 times
