Exhaust woes
Exhaust woes
The mild steel rear box on my SE is disintegrating rapidly. Until I can get a proper S/S exhaust, has anybody ever managed to lash together a temporary replacement using bits from other cars? I can weld something together if I can find some sort of rear box. All suggestions welcome!
Re: Exhaust woes
I did something similar, too cheap to properly fix the blown rear silencer on my 1500, I just bought a generic silencer of roughly the same length off ebay. Chopped the rotten one out and welded in the new one. It held up fine till I switch to a Sprint engine and it passed the MOT.GIX 7 wrote: ↑Fri Jan 15, 2021 10:18 pm The mild steel rear box on my SE is disintegrating rapidly. Until I can get a proper S/S exhaust, has anybody ever managed to lash together a temporary replacement using bits from other cars? I can weld something together if I can find some sort of rear box. All suggestions welcome!
Not difficult to do, as long as you get the right diameter silencer. Just make sure you got your angles right when you weld it on, so the tail pipe sits in the right position.
I believe you want 38mm, the cheapest I can find is 30 quid at the moment, which is more than I paid.
Re: Exhaust woes
Thanks for that advice, I will start looking around for one!
Re: Exhaust woes
I made my own exhaust buying bits of ebay
Re: Exhaust woes
Sorted.
Went to a scrapyard, found an exhaust off a 1990 Micra, and welded the expansion box in to the old system. Looks good, sounds good, and will keep the wolf from the door for a while!
Re: Exhaust woes
Being a cheap skate when the over axle section fell apart I cheated and made a side exit pipe that comes
out under the rear passengers door
Re: Exhaust woes
See my post on alternative exhausts last August, bends still for sale.
