It is currently Wed Apr 21, 2021 7:19 am
Post new topic Reply to topic  [7 posts ]
 Post subject: Soda blasting
PostPosted:Fri Mar 19, 2021 6:32 pm
Iv'e got a front panel which has some light surface rust, any idea how much to have it soda blasted ? :D
1977 Flamenco sprint (VGY NOW TAX AND MOT FREE :D )
 Post subject: Re: Soda blasting
PostPosted:Fri Mar 19, 2021 8:18 pm
soda blasting is unlikely to take rust off an older panel.
PostPosted:Fri Mar 19, 2021 8:34 pm
Ok, it's never been fitted and is a repro front panel, was going to put it on Ebay but it has some very light surface rust and i wanted to remove it and then maybe give it a coat of primer :D
PostPosted:Fri Mar 19, 2021 8:54 pm
If it's only light rust, rub it down by hand with some wet & dry, then prime.
Modified Dolomite Sprint MSO 662P
PostPosted:Fri Mar 19, 2021 9:20 pm
I sort of have on the outside of the panel but it's the nook and crannies on the back i was hoping to get cleared up, maybe will give it a go with a light wire brush or a drill with a sanding flap :D
PostPosted:Fri Mar 19, 2021 11:25 pm
if you are selling it then personally I would just give it a light clean to get rid of the worse, don't paint it as most people want to see what they are buying and painting i makes it look like you are hiding rust so may put people, the buyer will likely want to get it cleaned and properly painted anyhow.
PostPosted:Sat Mar 20, 2021 9:41 am
:thumbsup: :thumbsup:
Display posts from previous: Sort by
Users browsing this forum: AhrefsBot [Bot], Bing [Bot], SEMrush [Bot] and 2 guests
