Lucas Rists terminals
- RichardHyde
Hi all,
Does anybody know where I can buy a few Lucas Rist terminals ? These are the pin connectors in the wiring loom plugs.
Thanks, Richard
Thanks, Richard
Re: Lucas Rists terminals
Richard
Try Auto Sparks, i may have some
- RichardHyde
Hi Dave, they’re out of stock too !!
Thanks, Richard
Thanks, Richard
- yorkshire_spam
- RichardHyde
Yes thanks. Have ordered some from them before but now all out of stock. Have asked them if they’re expecting any more stock...
- yorkshire_spam
Hmmm, you are right, most places seem out of stock or want a million quid for them or will only supply complete with housings not just the terminals. How annoying!
Unless originality is really important to you, my advice is bin them and fit something different. As long as the connector type you buy is rated for the power you're going to put through it, it doesn't really matter how two wire are connected up.
These guys seem to have every type of connector you ever heard of
https://www.automotiveconnectors.com/co ... ls/page/2/
Russ Cooper
Dursley
UK
Dursley
UK
Be aware there are two types of round rists terminals. One holding tab and two holding tabs. Both are different and have their own housing type.
They certainly have an impressive selection of connectors!dursley92 wrote: ↑Wed Sep 08, 2021 12:27 pm These guys seem to have every type of connector you ever heard of
So far as the Triumph Toledo & Dolomite connectors are concerned, I think it's Page 3 of 8 that is appropriate:
https://www.automotiveconnectors.com/co ... ls/page/3/
https://www.automotiveconnectors.com/lu ... 16awg.html
https://www.automotiveconnectors.com/lu ... minal.html
In the past, I have simply reused the old male & female brass connectors, in the various sizes of multi-way connector blocks, that I have salvaged from the car breakers' yards. It's what I did when I substituted the Dolomite adjustable steering column and sculptured dashboard into my 1974 Triumph Toledo 1300 in 1982/83 & 1984 respectively.
Regards.
Nigel A. Skeet
Nigel A. Skeet
Here is another source of Rists terminals, who also supply replacement grommets.
https://www.3waycomponents.co.uk
https://www.3waycomponents.co.uk/Lucas-Rists-Grommets
https://www.3waycomponents.co.uk/Automotive-Connectors
https://www.3waycomponents.co.uk/Lucas- ... m-51101170
https://www.3waycomponents.co.uk/Terminals-and-Sleeves
https://www.3waycomponents.co.uk/Termin ... -Terminals
Regards.
Nigel A. Skeet
Nigel A. Skeet
I have some white, black & red 20-way connector-blocks, from one or more BLMC cars, but I have yet to attempt removing the brass connectors and recycling them. Further investigation of currently available, multi-way connector blocks, revealed that these are Lucas-Rists TTS connectors, coloured either black, white, red or blue, in 3-way, 5-way, 7-way, 9-way & 20-way forms; stocked by 3 Way Components, in Luton, Bedfordshire. It appears that the captive brass connector pins & sockets are identical or very similar to those used in the Toledo & Dolomite.
https://www.3waycomponents.co.uk/Automo ... Connectors
https://www.3waycomponents.co.uk/Automo ... ector-Kits
https://www.3waycomponents.co.uk/Automo ... r-Housings
https://www.3waycomponents.co.uk/Automo ... eeper-Bars
https://www.3waycomponents.co.uk/Automo ... -Terminals
Regards.
Nigel A. Skeet
Nigel A. Skeet
- RichardHyde
Thanks, but when I tried to order they had none in stock !!
Try contacting Lucas-Rists directly and ask whether they have any other stockists.RichardHyde wrote: ↑Sun Oct 10, 2021 8:19 am Thanks, but when I tried to order they had none in stock !!
Regards.
Nigel A. Skeet
Nigel A. Skeet
