Lucas Rists terminals
RichardHyde
#1 Post by RichardHyde »
Hi all,
Does anybody know where I can buy a few Lucas Rist terminals ? These are the pin connectors in the wiring loom plugs.
Thanks, Richard
new to this
Re: Lucas Rists terminals
#2 Post by new to this »
Richard
Try Auto Sparks, i may have some
RichardHyde
#3 Post by RichardHyde »
Hi Dave, they’re out of stock too !!
Thanks, Richard
yorkshire_spam
#4 Post by yorkshire_spam »
RichardHyde
#5 Post by RichardHyde »
Yes thanks. Have ordered some from them before but now all out of stock. Have asked them if they’re expecting any more stock...
yorkshire_spam
#6 Post by yorkshire_spam »
Hmmm, you are right, most places seem out of stock or want a million quid for them or will only supply complete with housings not just the terminals. How annoying!
cleverusername
#7 Post by cleverusername »
Unless originality is really important to you, my advice is bin them and fit something different. As long as the connector type you buy is rated for the power you're going to put through it, it doesn't really matter how two wire are connected up.
Magenta Auto Sprint
#8 Post by Magenta Auto Sprint »
dursley92
#9 Post by dursley92 »
These guys seem to have every type of connector you ever heard of
https://www.automotiveconnectors.com/co ... ls/page/2/
Russ Cooper
Dursley
UK
#10 Post by soe8m »
Be aware there are two types of round rists terminals. One holding tab and two holding tabs. Both are different and have their own housing type.
naskeet
#11 Post by naskeet »
dursley92 wrote: Wed Sep 08, 2021 12:27 pm These guys seem to have every type of connector you ever heard of
They certainly have an impressive selection of connectors! :D
So far as the Triumph Toledo & Dolomite connectors are concerned, I think it's Page 3 of 8 that is appropriate:
https://www.automotiveconnectors.com/co ... ls/page/3/
https://www.automotiveconnectors.com/lu ... 16awg.html
https://www.automotiveconnectors.com/lu ... minal.html
In the past, I have simply reused the old male & female brass connectors, in the various sizes of multi-way connector blocks, that I have salvaged from the car breakers' yards. It's what I did when I substituted the Dolomite adjustable steering column and sculptured dashboard into my 1974 Triumph Toledo 1300 in 1982/83 & 1984 respectively.
Regards.
Nigel A. Skeet
naskeet
#12 Post by naskeet »
Regards.
Nigel A. Skeet
naskeet
#13 Post by naskeet »
I have some white, black & red 20-way connector-blocks, from one or more BLMC cars, but I have yet to attempt removing the brass connectors and recycling them. Further investigation of currently available, multi-way connector blocks, revealed that these are Lucas-Rists TTS connectors, coloured either black, white, red or blue, in 3-way, 5-way, 7-way, 9-way & 20-way forms; stocked by 3 Way Components, in Luton, Bedfordshire. It appears that the captive brass connector pins & sockets are identical or very similar to those used in the Toledo & Dolomite.
https://www.3waycomponents.co.uk
https://www.3waycomponents.co.uk/Automotive-Connectors
https://www.3waycomponents.co.uk/Automo ... Connectors
https://www.3waycomponents.co.uk/Automo ... ector-Kits
https://www.3waycomponents.co.uk/Automo ... r-Housings
https://www.3waycomponents.co.uk/Automo ... eeper-Bars
https://www.3waycomponents.co.uk/Automo ... -Terminals
Regards.
Nigel A. Skeet
RichardHyde
#14 Post by RichardHyde »
Thanks, but when I tried to order they had none in stock !!
naskeet
#15 Post by naskeet »
RichardHyde wrote: Sun Oct 10, 2021 8:19 am Thanks, but when I tried to order they had none in stock !!
Try contacting Lucas-Rists directly and ask whether they have any other stockists.
Regards.
Nigel A. Skeet
