National Restoration Show & Autojumble Sun 25th October
tom16v
Re: National Restoration Show & Autojumble Sun 25th October
#46 Post by tom16v »
Had my first master class yesterday! Got rid of all the surface rust and stone chip and primed the panels all up in the same colour.
Here are some pics. Eyebrows are done too but forgot to take photo.
Thanks again for the use of your tools and all your help Nathan.
See you all soon.
Tom.
1979 Carmine Dolomite Sprint
2005 Mystic blue BMW M3
2004 Mystic Blue 330d
2001 Peugeot 206 Hdi180
Nathan Mwk 627G
#47 Post by Nathan Mwk 627G »
No problem Tom, anytime!!
Hope there prepped enough for the show!!
Well done for posting the photo's......and showing how messy my garage is :lol: :lol:
Nathan
#48 Post by xvivalve »
Ah, its a repro front panel!
Take your plastic egg crate grilles and test fit them in the apertures of the new panel to ascertain whether or not you will be happy with the appearance. You might need to fettle the depth in order to get them sitting satisfactorily...
Purplebargeken
#49 Post by Purplebargeken »
and you might want to take the bits of panel that will be welded back down to bare metal and prime them with weld thru primer instead.
Nathan Mwk 627G
#50 Post by Nathan Mwk 627G »
purplebargeken wrote:and you might want to take the bits of panel that will be welded back down to bare metal and prime them with weld thru primer instead.
Tom has bought some weld thru primer for the very task, last night we primed them in zinc primer to stop them from rusting,as they will be in Toms garage for 2 weeks!!
Nathan
Purplebargeken
#51 Post by Purplebargeken »
:oops:
TLC
#52 Post by TLC »
:bluewave: Ill be watching all the skilled work going on and taking plenty of pics to help me with my :oops: restoration .If any one has any new or good SH dolly eyebrows they are willing to sell or a mint tan drivers door card letme know before the show please :)
Purplebargeken
#53 Post by Purplebargeken »
Now don't be doing too much sanding, etc, beforehand otherwise my 'lecky DA will be most upset.
triumphdolomiteuk
Site Admin
Site Admin
#54 Post by triumphdolomiteuk »
We are going to need a welding screen, something to shield the public from the flash from the welding. Any ideas? We also need some powerfull lights to illuminate the work area. Any offers?
Purplebargeken
#55 Post by Purplebargeken »
I think I might have a halogen bulb work light on a stand. Have to check it still works though. Will check tomorrow and report back.
tom16v
#56 Post by tom16v »
Just popped out to the garage and did a bit more investigating.
I found this:
Spoke to Nathan and he is going to get me some sheet metal to make up a repair panel with and doesn't think it will be too much trouble. Will need to be sorted before the wing goes on though.
Alun - The kidney grill bits are in the boot ready to be used to help line the front end up. It is miles out at the moment but I think it will be easier to get it right when the rest of the front end is in place?
I guess we will need an assortment of hammers other stuff to change the shape of panels though? I know nothing about this so suggestions would be great.
Tom
#57 Post by xvivalve »
The kidney grilles are trim and do not contribute to the alignment of where they sit, they just emphasise how crap it is. What I am attempting to fore warn is nothing to do with alignment and cannot be rectified by panel adjustment as they are fitted. The repro front panels are notorious for having insufficient depth for the grilles to sit in and they therefore protrude from the aperture once fitted, it is this that I am asking you to test fit as you may wish to adapt the flanges to accommodate them! Once the panel has been fitted you will not have opportunity to redress this...
Zinc based primer is hydroscopic incidentally, so your nice grey panels will attract and hold water if stored anywhere with humidity or dampness. Weld through primer is non hydroscopic,
Purplebargeken
#58 Post by Purplebargeken »
T2hE halohjgen alighte1o31 works j0923uust fine. I akQm sure m LKy sight will recQVer.
Nathan Mwk 627G
#59 Post by Nathan Mwk 627G »
purplebargeken wrote:T2hE halohjgen alighte1o31 works j0923uust fine. I akQm sure m LKy sight will recQVer.
you had to much wine Ken??
Purplebargeken
#60 Post by Purplebargeken »
At that hour of the morning?
Nope, partially blinded by the bloody halogen work light. Crikey is it bright!!!
