been faffing around under the bonnet and with headlining, been frustrated at my lack of oomph, so bit the bullet and after gluing down the headlining on the driver's side C pillar, realised I need to do the vinyl and sprint badge first, so quickly unglued it.
the seamed C pillar vinyl from martrim, courtesy of MickeyB (fettling) and 80sflamer (transporting), was easy enough to apply. I used contact adhesive and had little problem.
I still need to remove the masking tape I used to protect the paint and cut away the excess vinyl at the bottom.
Then, the big step, put on the roof vinyl. I read up on Mart's thread and followed his lead. Marked the centreline and worked from the centre of the roof out. I used clips to secure the vinyl in position on the passenger side while we simply pulled it tight and rubbed it down on the driver's half of the roof. Did it in 2 stages each side.
resting in place, clips providing the alignment
spray adhesive. We used high temperature headlining and carpet adhesive.
sprayed and ready to be rolled down. We found that applying tension to the vinyl and rubbing it with hands worked well.
holding it with clips meant we didn't have the problem of lifting it and making sure the first contact was exact, the clips had it lined up.
driver's side down. We used the blunt end of a shifter to rub the vinyl into the gutter, leaving it poking up over the rim. I'll stick that down over the rim tomorrow when it has set in the gutter
passenger side done
the gutter. The front and rear edges have been glued down but the gutter is a quandry.
I have the clips that slip over the gutter rail, but I don't think they are needed. they appear to be used to hold the vinyl around the gutter rail. The one with the "D" tag is obviously used to hold the A pillar extension of the vinyl down, but even that seems overkill.
How many of these small clips ae needed ? The chrome gutter trim will clip in easily over the rail and underneath the roof (around another ridge) without the clips. Should I use any clips or rely on the contact adhesive ?
Inside the car the B pillar interior trim is about to go on. I had a win on ebay with some second hand furlex/pinchweld which is in really good condition. the door rubbers are now all on. I've taken apart the washer bottle holder and pump and resprayed that and I'm looking nervously at the headlight fittings, all the broken plastic hex adjustment bolts.
thanks again to Darren and Mike for getting the vinyl out to me.
Tomorrow I load the youngest (henry) into the boot while I tighten the rear suspension up and finish the roof vinyl. Then I need to think about what to tackle next. Probably some interior sound insulation on the inside of the firewall and headlights. I'm holding off on putting the engine back in for as long as I can to give me easy access to the engine bay.
stu
