Will an overdrive box from a 1500 fit, and will i need the rear axle too. Also is a 'J' type okay to use, and what on earth is the difference between the three rail and single rail
As far as I know, yes.pandaselecta wrote:Also would a spitfire 1500 overdrive box fit, as a spitfire has turned up at a local scrappy
yes. A lot of Shitfire owners raided Dolomites for their gearboxes, so it would be nice to see one being taken back. Just be carefull, most 1500 / 1850 overdrive boxes I've tried have had a slipping o/d unit.pandaselecta wrote:Also would a spitfire 1500 overdrive box fit, as a spitfire has turned up at a local scrappy
What everyone else said above, you want the box from a 1500 or spitfire.pandaselecta wrote:been looking at putting an overdrive box into the toledo, but i dont know what type to look for?
