Spent some time today cleaning off the algae and cutting back the paintwork to see what needs doing. Overall not too bad, some shallow dents and rust spots but nothing to write home about. The two n/s doors are a bit wounded but bearable. I also filled the 3 small holes along the C pillar and the couple of bits on the wheel arch.
Cleaned up the dash a bit which will hopefully protect it whilst the car slumbers a little longer. Replacement carpets and seats will make a huge difference to the car. The crash pad on the parcel shelf will need replacing at some point. The steering wheel will be replaced with a Dolly item for now. The original is quite worn and moth eaten.
The clutch and brake pedal are solid. If I get the chance, I will remove the cylinders and replace hopefully.
The drivers wing will need to be replaced. I think the passenger side wing will repair, but the lower section will need cutting out for sure. Apart from the sill and a patch underneath and the boot patch that might be it. The rest is cosmetic. Oh and a couple of new screen seals wouldn't go amiss either. All in good time.
The engine bay will need the most tidying
