Aaron's 1976 Dolly 1850HL Custom.
Re: Aaron's 1976 Dolly 1850HL Custom.
No worries mate, I'll drop by and pick it up on my way home from uni, I'll pm you the day I'll be heading down, I'm pretty sure it'll be a saturday morning. Be a good chance to see the Sprint while I'm there aswell
Hey guys, time for another update!
After some serious and painful dealing that lasted me a good 3 weeks, I've finally gotten my 3" Peep Mirrors. They look great and were a steal for $70.00 aus.
I am left with very little parts to source now, here is the list:
- I/R seatbelts x2 $210.00
- Alpine type R Component Speakers x2 pair $600.00
- Dixieland Air Horn Kit $110.00
- Paint, Gel Coat, Thinners, Primer est $500.00
- Whitewall Tyres est $160.00
- Exhaust system including extrcators est $900.00
- Suspension springs/ shocks (TBA)
- New Black Carpetting (in boot only) est $4.50 per square mtr.
- mirrors 001.JPG (50.18 KiB) Viewed 3838 times
Hey guys, about time I added abother update.
Progress since last update:
-Starter Motor re-fitted.
-New 326 CCA 50 RC Bond Battery Fitted.
-Battery clamp holds battery in very tight!
-New Terminals, one of which needs to be replaced yet again as it's not tightenning on the negative connection for some strange reason.
-CD/MP3/ipod CD Player fitted and running off the stock Braided and fused wire off ignition (man that's old school!)
-Push-button starter fitted but not yet tested.
-Most of the electrics are working.
-Bought second hand XF series Ford Falcon Alternator (75amp) in similar orientation to the triumph one for $10.00.
-Radiator re-fitted.
-Filler cap freed using extension bar (that was a prick of a job, but now I can fill the system properly)
-Driveshaft removed from car (Still trying to fit the centre bearing)
-Paint Quotes sourced and final Rat-Rod style design complete.
-Dixie Multi-tone air horn fitted and working (switch on drivers side dash pannel)
-RCA leads and Remote wire siliconed in under carpet and concealed.
-Amplifier rack mocked up, to be test fitted late this afternoon.
-De-badged fron valance and C Pillars.
-Shaved original door mirror holes.
-3" Door frame mounted Peep mirrors fitted.
-Front indicators, high and low beams fitted and working (sort of)
-Front spoiler test fitted.
There is much more to come, but I'll get there
Anyways, have a look at some pictures, and if you were linked here from my other post, here are the requested pics.
- Dolly762.JPG (49.49 KiB) Viewed 3761 times
- Dolly763.JPG (68.74 KiB) Viewed 3762 times
- Dolly768.JPG (62.97 KiB) Viewed 3758 times
More Pics:
- Dolly765.JPG (57.79 KiB) Viewed 3753 times
- Dolly7611.JPG (75.89 KiB) Viewed 3753 times
- Dolly761.JPG (55.79 KiB) Viewed 3748 times
Even More Pics:
- Dolly769.JPG (53.63 KiB) Viewed 3743 times
- Dolly766.JPG (63.48 KiB) Viewed 3740 times
- Dolly764.JPG (51 KiB) Viewed 3740 times
Oh, yes.... if anyone's wonderring, that "IS" the original woodgrain, never re-furbished, all original and untouched!
can you let me know how this goes Aaron. I've been searching for a lucas A127 equivalent and should just try some my luck with some likely candidates I think.-Bought second hand XF series Ford Falcon Alternator (75amp) in similar orientation to the triumph one for $10.00
check out sprintparts service bulletin on the different mounting sequences for the centre bearing. Apparently it matters how you bolt it back up and this differs car by car.Driveshaft removed from car (Still trying to fit the centre bearing)
Did you get that interior rear vision mirror on ebay ? The one I told you about. I bidded for it but didn't want to go too high in case I was bidding against you on something I was buying for you !
thanks for the pics, time I uploaded what I have been doing.
stu
Ahh good thing you asked stu, I've actually opted to go for a mirror that glues up to the windscreen if nothing else comes along.
I'll definately let you know about the alternator, obviously it isn't fitted because roadworthy guys are such tightarses
But I'll be at that stage soon, where all the "fun" parts get bolted in.
I may be doing the fuse box tomorrow
Oh btw stu, did you win the mirror? If so I'll pay to have it posted over
My Ebay username is triumphnut78 if that helps
nah, I didn't win it, pulled out at $12 iirc. I still have the spare one here if you need it, not perfect though. The ebay username is not that useful now that they've hidden the bidder ID, but if you look at the feedback rating, you can sometimes make an ID. My username is moelfre btw. I've just won a 17ACR alternator from Ozbaz to at least get me a few more amps, my alternator was only a 15ACR. Every little bit helps and for $15 it was worthwhile.
stu
stu
Aaron, just a hint. The fuzzy fabric on the door card can be made beautiful again by spraying with simple matt black paint from a rattle car. Works wonders
Done it quite a few times.
Cheers Ken! Top Gear style concours? HAHAHAHA that episode was hilarious, I might give vinyl die a go though I reckon
Hey guys, time for a new update.
Sadly money and time issues have slowed the Progress on my little dolly right down, and as a result I'll be driving dad's Holden rodeo to uni in Adelaide
But... good news is, come monday I'll have the entirety of the interior back together, with the boot all welded up and safe and will have the car basically ready for paint. I'm still dabbling with starting issues.... so that's another thing for another day.
I got a lockable radio antenna that hides away almost completely. it has a nifty little key that you use to open it up, very low tech.... the way i like it
AS far as other things I've done... I'll have to think on that
Lol! i can't remember what I did last tuesday! Pics tomorrow
I used to have the best aerial ever on my Beetle 1303S. It was spring loaded - you had a little key you pressed into a small hole in the side and the whole thing shot up in the air! Quite lethal, but very amusing.DOLLY76 wrote:I got a lockable radio antenna that hides away almost completely. it has a nifty little key that you use to open it up, very low tech.... the way i like it
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
