Fitted with solid rack mount on one side...
Anyone know what this prop. is from? Certainly not a standard Sprint prop..
Never mind though, you can easily enough swap them over during the rebuild.Fitted with solid rack mount on one side...
No it's not an early one, but I expect you guessed that because it isn't Mimosa.taihitiSPRINT wrote:So what’s the story with THJ?
Is it an early one (pre-VA2000)? With or without overdrive? Does it have history?
And do you already know what improvements and/or modifications will be included in this resto? I’m sure the experience you've build up from the previous ones will sport some nice additions
