MoT overcome.
The very bent and filler-laden rear panel has been chopped off and replaced with a new-old-stock panel. (£5 from TDC stock!). The inside of the boot has been resprayed in body colour
All exterior trim has been removed.
Door trims and rear seats are out (a 10mm spanner was found inside the offside rear door)
Fuel tank has been removed. The bottom had slight surface rust, which has been both painted in epoxy mastic and reinstalled.
Bumpers are now off. The rear one is both rusty and bent. A new 3-piece replacement will go on.
Engine has been cleaned of black sludge and its crank bearings changed.
Engine has had a full service and new ignition parts fitted.
Nasty dent (and rust hole) in the nearside rear quarter panel, which was covered in filler, has been pulled out and welded up.
Old tyres stipped, rims shot blasted and repainted. New tyres fitted.
Offside and rear paint prepared for paint, covering my garage and utility room in filler and paint dust.
Cockups made:
Put a dent in front of the immaculate roof, thanks to me kneeling on it to get to a shelf in the garage. Most popped of it out but filler had to be used.
Scratched the nose badge badly - goodness knows how. I have a reasonable second-hand one but could fit a new one if the paint finish comes out well.
Somehow put a dent in my fresh new rear panel. Again, I know not how. Had to fill it but, thankfully, it was shallow.
Plans:
Get the nearside prepared for paint.
Etch prime any bare metal spots.
Tax the car on Feb 1st
Drive the car to painters for filler priming on 2nd Feb.
Collect the car on 5th Feb
Prepare the car over Feb.
Have car painted in very early March in top coat.
Phew!
R
