advice on dolomite for road rallying
Nick C
Re: advice on dolomite for road rallying
#1 Post by Nick C »
Hi Will,
IMHO an 1850 would make a very good road rally car. It'll never be as competitive as a top-spec Welsh Escort, but will be an awful lot cheaper to build!
I'm a road rally navigator, so I've sat in all sorts of things :) For a RR build, you're looking for reliability above all else - you can't go stupidly fast as you're on the public highway after all. The Dolly has proper twin-wishbones at the front, and 4-linked rear, although the standard brakes are a bit weak - TrackerJack on here sells a conversion using Sierra calipers and Golf discs which makes them a lot better. The slant-4 is a nice torquey lump, and at a rough guess I'd say the 1850 is slightly slower out of the box than a 1.6 205 - A stock Sprint would be similar to a Golf GTI 16v. The Sprint is one of the very few 16v cars that can be road rallied on carbs, as it is a single cam (the road rally rules only allow cars with more than one camshaft per bank if they are fitted with the original injection system...)
Like all cars, the shell would warrant strengthening if you're intending to do rough events, and the lights could do with upgrading (6" KC daylighter lenses drop straight into the 5 3/4" housings on a twin-light Dolly)
You don't mention whereabouts in the country you are or what type of events you intend to do? If it's historic, the brake mods etc won't be allowed, there were period brake mods for the Sprint, but the bits are hard and expensive to find now...)
HTH,
Nick
David6214
#2 Post by David6214 »
How ironic that my tolly is rally prepped and came from the north only a few short weeks ago.....
NFXdynomite
#3 Post by NFXdynomite »
Now then Bill i would say the 1850 would be perfect for a starter Dolly on road rallies and historic events.
I run a Sprint on both types of events with varying success, see the motorsport section, i reckon you could be fairly competitive too though.
You would have to invest in some decent brakes, Rimmers do an EBC upgrade kit which int out the way price wise, and have a look at the handbrake situation.I replace mine with a hrdraulic version and got rid of the cables, it works well for historic events but is a bit S****e on road rallies :lol:
You might want to invest in some decent shockers too preferably adjustable to raise the front end a little,poly bushing could help i prefer a mix of rubber and poly as you need a little give.
O and make yourself a sump guard of some sort this is probabky the most important :roll:
hope this helps if you need any help im in Hull or get in touch :)
John
NFXdynomite
#4 Post by NFXdynomite »
David6214 wrote:How ironic that my tolly is rally prepped and came from the north only a few short weeks ago.....
Dave i think i know this one was it a young lad you bought it off?
Nick C
#5 Post by Nick C »
NFXdynomite wrote:replace mine with a hrdraulic version and got rid of the cables, it works well for historic events but is a bit S****e on road rallies :lol:
Except that it is illegal to remove the cables, and the car should fail both MOT and Rally Scrutineering if there is no mechanical emergency brake fitted...
NFXdynomite
#6 Post by NFXdynomite »
i put the cables back on for mot nick :wink:
