the gloss black really does suit it out in daylight, makes it look really mean
stu
lwalton wrote:car looks excellent how is the fire wall material any good?you started yours roughly the same time as me and mine is just a bare shell still,paint job looks superb. lee
montythemole wrote: Black and silver plates really suit it too (did I give you the original ones as well in the sale? If not let me know and I'll try and look them out).
lwalton wrote:i had a similar problem with my starter motor and i traced it to the gearbox wiring loom which i had unplugged which has a link wire and that in turn energizes the starter, i had all the symptoms you have had i took out the starter tested it all was fine fitted it back in and nothing.I am a electrician by trade for the last 11 years and i spent two days tracing the problem try it you may solve your problem
I have a standard stainless system that'll be cheap. Some of the hangers have broken off so the choices are use the alternative mounts the PO has put on or weld on something more original.johnnyv1 wrote:Anyone have a system (standard or sports) they want to be rid of? (cheapish) just a thought.
