Sprint Restoration in South Australia (pic heavy)
Ahhhh.................
The sweet sound of success!
Re: Sprint Restoration in South Australia (pic heavy)
a few weeks down the track and a little more progress. Sorted the dash lights out, fixed a tacho that wasn't working, stuck down the vinyl along the windscreen that had lifted in the heat, retorqued the head and went for an extended run of the engine:
http://www.youtube.com/watch?v=lA4Bv4h2lTI
kids helping with the video. Lots of choke here, reducing the choke brings the engine back to 2 and then 1 cylinder
Temp was run up so that radiator top hose got warm and therefore thermostat had opened. Blowing smoke out of the hole I made in the exhaust manifold for the O2 sensor.
Then, with a 3' forward and back reverse under my belt, we went for a quick jaunt around the shed paddock. Not wanting to rev the engine too high after the rebuild (at least not until it is running smoothly) she did the circuit mainly on choke.
http://www.youtube.com/watch?v=XsQn88dsb5A
Car is booked into George for installation of screens and black spraypaint in the week after easter. George will also cut back the paint and buff her up.
The classic car club registrar will drop in when he finds some time so I can get historic rego for her. Stop after that will be into Naracoorte (45km) to get a wheel alignment and the exhaust made up. Under her own steam !
then the tuning starts in earnest and she will get tarted up for the clubs "show and shine", start of May.
Then she will get used the 90 days a year I'm allowed to drive her for !
stu
stu
Looking great stu!
I wish I was this far along. Maybe if I won tatslotto I could get it all sorted whilst I'm at uni LOL!!!
Ahh well, spanner time is a personal thing to me anyways so I'll get there. I finally watched the video of the old girl driving last night, looks like you gave her a bit of juice on the trip back to the shed, and who could blame you?
Keep up the good work champ. If there's anything you need from Newport Motors while I'm up here give me a buzz and I'll see what I can find.
time for another biggish update. Well, one with lots of pics.
Drove her down the road back to george's two weeks ago for the black paint, glass and some trim. One eye watching for the local bobby, it was good to drive her on an actual road and even with a lot of choke, she had that sprint "kick" when the throttle is given a tickle. Tested the OD and that worked, so good news there.
I fitted up the tunnel after fixing up the clutch master, which had for some inexplicable reason, thrown the master rod back into the drivers compartment. Bled it again and made sure the circlip was properly seated. I had cut a section out of the passenger side of the tunnel and for sound/thermal insulation used a mousemat, which provided a nice tight seal. More insulation goes over the top, inside the car. Fitting it back proved to be one of those 5 hour jobs. I have a theory that every job on the sprint takes 5 hours, from 1pm until 6pm, no matter how apparently trivial or how complex. Refit the engine, 5 hours, refit the rear lights, 5 hours. All the same.
anywho, onto the first of the pics:
the hole, for accessing the clutch slave, should I need to do so
with plate over, showing the mousemat insulation (more on mousemats later)
down at George's, fitting the rear screen. Good seals (from Vangaurd spares in melbourne, $100 each). George was very patient and the screens slid in like magic, with his tricksy rope thing. Silastic seal underneath.
taping up for the black. Bootlid fitted up well and bonnet likewise. Nervous moments wondering if the bonnet would open up, but steady, logical steps building up to the "shut it" moment proved successful.
George didn't take any chances of getting black in the wrong spots
sprayed and glass in.
satin black used on the sills and back.
I tried the dishwasher trick on the tail light lenses.
more mousemat goodness. Ideal stuff as far as I can tell, for the gaskets around the tail lights and front indicators. Cuts easily, stays in place well, correct thickness and gives a great seal.
tail lights in
after a bit of debate, we fitted back the bottom weatherstrips, using the correct clips. We broke 3 clips and didn't use any glue. Hoping that keeping the car in the shed and out of rain/salt air will prevent rust in this area (that and a lot of fish oil in the sills)
boot lock, greased up, grease was later cleaned up a bit. The lock actually fouled the latch, so the boot lid was moved forward a few mm. It still sits well, but a little high on the left side front. maybe 2mm.
onto bumpers, another 5 hour job. Wire brushed back on the inside, masked up, hit with rust eater then sprayed with black zinc. From the treasure trove that came with Thomas' sprint, I was able to find some good bumpers, not perfect, but not too bad. I had thrown the overiders into the rubbish skip at Darwin naval base in 1988 when I put the spotlights on, thinking I'd never need them again ! Luckily a pair came up on ebay for $20 and they were in excellent condition.
rear bumper fitted up, a bit of faffing around here. I managed to drop the mounting bolt behind the petrol tank and it slid out of reach. Needed to take the petrol tank out (drain etc) to retrieve it
In the end, we attached the side points first over some rubber gaskets, finding the caged nuts (all treated with never seize) with the bolts. then using vinyl gaskets on the rear mounts, swung the bumper into place.
front bumper was easy. same rubber gaskets on the sides, fitted the mounting brackets to the bumper, then fitted the bumper to the car.
Son's sprint in the background. This was an ebay purchase for $1400. Absolute bargain and in really good condition. It is still waiting for Thomas to get busy with the angle grinder to remove the rust around the brake servo area. I wish my sprint had been as good as that. George had apoplexy when he saw it. called me all sorts of rude names for being stupid enough to work on a sprint that was so badly rusted when good shells can be picked up for not much money. I think Mark lamour said something similar on about page 4 of this resto thread.
now the bad parts. No matter how I do it, these air bubbles undeer the vinyl just won't go away. I lifted the vinyl and reapplied contact, but it just won't sit down.
I was worried about the chrome locking trim fitting the rubber windscreen seals after talk elsewhere on the forum. Luckily it seems the rubber supplied in Oz has the correct channel for the locking strip I got. Fitting it in was a pain though (yup, 5 hours) and I eventually settled on painting the strip with soapy water to help ease it in (lacerating my fingers doing so). A wooden pressing tool was good, but put very small dents in the strip.
pretty tight at the trailing edge of the bonnet. That is the best adjustment we can get, any further forward and it fouls the front as it opens.
Next step is waiting for historic rego check/verification. Passenger seat in, exhaust made up and fitted, fan blower back in, parcel shelf back in, windscreen wipers, chin spoiler, stereo, door cards and a tune.
Aaron, I've got my eye on a white dolly front passenger door at Newport, if you are up there and have space to lug it back to the SE, that would be teh awesome. He's holding it for me, I'll need to slip him the cash though. thanks for the offer. If you need any chrome trim, I have a bit surplus !
stu
tail lights in
stu
Fabtastic stuff mate.
But, don't it feel funny driving the car for the first time though eh? A heady mixture of both fear and excitement!!
Yes ............
Excellent, after 28 pages of this thread your Sprint is finally starting to look like a Sprint, Stu
thanks guys, and yes Alan, it did feel weird
meting with the historic club in Naracoorte tonight, try and talk the registrar into looking at it earlier rather than later. The show and shine is on first weekend in May, without rego I won't be able to show it.
stu
stu
Sympathy on the door trim clips mate...
I acheive a similar rate of attrition...
Ive started to get better results by making sure the first push through the holes isnt too tight and put a drop oi light oil on the pin before tapping it through with a block of wood under the hammer.
You so needed the right tool for the screen trim. They come up on uk ebay quite often.
Looks really lovely. Mimosa sems a bit brighter in your Aussie bright light.
That is because there is no volcanic ash in the air "down here".Looks really lovely. Mimosa sems a bit brighter in your Aussie bright light.
Hi Stu, The car is looking real good, it is a credit to you and soon all the hard work, time and money will start to be enjoyed. Just looking at the date that you started this thread, March 2007, and I think that I may have said to you at the time, work out how long it is going to take and the cost and double both . How close was I the truth.
yup, a long time happening, with lots of other stuff getting in the way. But I've enjoyed every minute, and I'm continuing to enjoy every minute. Thanks for your help Mark (and Phil). Everyone's help on these forums has been exceptional, every question I've had has been answered quickly and accurately. It is like a dolomite helpline, but better than most other helplines I can think of
not quite the final part in the puzzle, but the historic vehicle club registrar okayed the sprint and on Friday I went in to pay the rego. Imagine my horror when, after not being on the road for 12 years, they had the cheek to charge me a $15 late fee for renewal of the rego !
Not a bad system eh ? I might change the plates to personalise them yet, but for now, WAB 460 is road legal again and coincidentally, registered at almost the same time of the year as the last occassion.
the rego fee ? $374 for 3 years and I'm restricted to driving her 90 days a year. No checks needed, no roadworthy, not even an identity check to see if I'd changed the engine. That includes the late fee ! Every time I drive her on the road, I have to sign a log book. I don't drive my family car for more than 90 days in the year.
three year rego. Nice
rear number plate was in good nick, front is a bit shabby, but good enough to be road legal.
First official drive ? filled her up with petrol this morning and had a little jaunt around town, no exhaust. So much choke though
stu
stu
Good to see it back on the road. Get that 1850 done next. I wish I could get mine back on the road.
the 1850 is a target for resto, but it is in the queue behind my sons sprint and the stag.
okay help time please.
first major problem is she is drawing a steady 3 amps from the battery with ignition off. I drew the fuses and checked that the ground isn't on a fused circuit. The internal light/door lights aren't on, the bootlight is not wired up. Starter isn't grounding out. Detached the regulator and no change. 3A is a sizeable current, 36W is going somewhere
That said, there is no telltale spark from the battery when the positive terminal is removed and connected, just 3A on the multimeter and it is rock steady. Any idea where to look for common grounds ?
The other smaller problem is no speedo. I've had the dash in and out a few times and reconnected the speedo drive cable, but the speedo, she doesn't flicker. I got underneath today and rechecked the gearbox take off point, looked good to me, the spindle was inserted well. Anyone have any ideas ? Any tricks to connecting the drive to the speedo ?
But the good news, lots of jobs done ! Chin spoiler back on, front grilles back on (a job best done before fitting up the radiator I found, retropsectively), badges all on, passenger seat in, fan blower back on and running. Airbox back on. The washer pump ain't working. the rear demister will never work because some doofus forgot to feed the conecting wire to it and now it is too late
Sorted out a problem with the rear lights, down to a faulty connector which turned off the tail light when the brake was used, and didn't turn the brake light on either. Discovered I need to revisit the interior light wiring and get a 12V supply up to it somehow, I'm thinking this will be first investigation tomorrow. The original 12V feed is currently isolated.
took her for an extended 20 minute drive yesterday and came back for some tuning action. More fiddling around than anything, followed the book for most of it. Checked and adjusted the ignition timing (from 16 BTDC to the recommended 10), running really roughly with some alarming backfires and run on, moved the mixture adjusters an equal amount of turns towards the rich end, got her to the point where she would run without choke, got a smooth 800rpm idle and checked the balance again. Obviously not up to trackerjack blistering 1/4 mile standard, but she is running smoothly enough. The throttle pedal isn't returning as it should so she hangs onto a 1500 rpm idle until the pedal is lifted, then settles down to a nice steady 850 rpm.
some very small oil leaks, mainly from the gearbox area.
driving to Mount Gambier on Wednesday to fit up a new exhaust and get the wheel alignment done. 130km there, another 130 back. I'll have this engine run in in no time !
stu
stu
Excellent, Stu. Colour is wonderful, and the mousemat ideas - ingenious!
I love it!
I am...........
Sorry Stu, I have not encountered this problem.straylight wrote:first major problem is she is drawing a steady 3 amps from the battery with ignition off.
My suggestion is that to solve it, you try disconnecting components one at a time. I would try the alternator first......
