Mad as a warehouse full of frogs but I love what you are doing with the car. Keep at it!
Ken
project dolomite 3500HL
Re: project dolomite 3500HL
Blimey ,,a few years later and this machine is still providing me sterling service
in 2011 i took the 3.5 out with a view to fitting a 3.9
I stripped both engines and found the 3.9 to be a money pit, but built it up with a fresh camshaft, ported 10 bolt heads and all the usual goodies
intact 3.5 cam lobe
worn to nothing cam lobe
various tappets in varying stages of destruction
Rebuilt the gearbox and found nothing at all remotely worn so just simply reshimmed it and miraculously a silent lt77s !
whilst the engine was out I upgraded the master cylinder to a Volvo 940 unit which was a direct replacement
with 250lb/ft this occured when accelarating up a hill so i beefed it up with some 4mm plate
inevitabley the 3.9 dropped a liner so i swapped it for a rebuilt 3.5 engine which its still running now
i bought this last year , a 4.6 which will be rebuilt with a view for 320+ lb/ft in the midrange
intact 3.5 cam lobe
I'd be interested to see how the clutch hydraulics work in that.
Does the slave clash with the dolly rack?
i'll post a picture when i next get under it but the slave cylinder sits level with the rack but the end of it sits behind the rack mount approximately 2.5" clear distance such that the bleed nipple is accessible via the gap between the cross members of the subframe everything is fairly tight fitting but nothing ever hits
I love this car, its so beautifully scruffy!
