i tried this, works very well, and very discreet.
[img
[img
[img
[img
These leds are availble from Maplins i think they come in a pack of 4, thanks to Justyn for letting me have this one.
Do Dolomites have a dimmer?JPB wrote:How does the LED cope with being dimmed? Is some sort of standalone VR used to reduce current to the LED as presumably it will remain at full brightness or fail entirely when the panel lamps are dimmed, if it's connected in parallel with filament lamps that are fed via a rheostat.
I'm thinking that the glove hole lamp or the gear selector quadrant lamps might be a better source of the feed for an LED, since they remain constant regardless of the setting of the instrument panel lamps.
1300dolly wrote:The LED comes from Maplins, about £6 for a pack of four
Stan Part wrote:I guess it only applies to later cars John - ones without that there fancy rheostat malarkey?
Yes, but from what Alan's said, I'm guessing that later cars make do with a simple on/off switch?1300dolly wrote:........Do Dolomites have a dimmer?
