Spring rates for circuit racing
gmsclassics
Re: Spring rates for circuit racing
#16 Post by gmsclassics »
Anyone with blacksmith type skills will be able to fabricate one to your spec using the old one as a template. Work out how you are going to mount it though as the current front brackets will need to be larger and stronger.
paulsprint
#17 Post by paulsprint »
Carl I've been asking my self the same question. When I get 5 mins I will look into finding a company who can make one to the same pattern. Not sure what steel to use either. If it is just a case of heating it up and bending it, shouldn't be that hard. Wound look at making it adj as well.
Oli_88
#18 Post by Oli_88 »
Didn't TJ modify a Sierra (What else? :lol: ) one to fit?
Then there's that Alfa Romeo one that's been made to fit in the states...
trackerjack
#19 Post by trackerjack »
Oli_88 wrote:Didn't TJ modify a Sierra (What else? :lol: ) one to fit?
Yep and sold it on Ebay for peanuts as nobody was interested.
It was 24 mm and worked well enough but I have standard back in at the mo.
gmsclassics
#20 Post by gmsclassics »
Photo shows how mine is attached - front mounting blocks are aluminium - and the adjustment mechanism
Geoff
trackerjack
#21 Post by trackerjack »
Oh yes I like that set up a lot and it means that a few holes make it adjustable 8) .
Lets gather some bits up and I will make a few :D
