Well things are progressing slowly .my finger is on the mend and now with help from my dad iv started taking the front suspenion to bits
the long job of stripping all the old underseal off everything is nearly done with a little help from a bowl of paraffin
2 coats of red oxide has now been applied to some bits the rest will get their 2nd coat tommorow then 2 coats of smooth coat black hammerite. hopfully this week il be ordering new boots for 3 of the ball joints ,the 4th being the orig upper with a grease nipple on is gonna be fully reconed as when cleaning the underseal off found that in its 37yrs of service the boots had desintergrated causing the ball to wear.have managed to get 2 recon kits from ebay today
.have now ordered my polly bushes for the front suspenion from superflex and have decided to replace the lower bush with poly aswell,just waiting on my local garage to phone me to say they have removed the lowers bush bearings for me
.and have orderd all new nuts,bolts and washers from rimmers aswell hopfully i havnt left none out .after that the wheel arches are gonna be stripped of all icky underseal and coats of por15 applied then a top coat of somthing called whitecote which is a 2pak white enamel paint .this is going underneath aswell .photos will be added as i progress watch this space
