Redtop sprint
Re: Redtop sprint
Well I got the Recaro bit right! Shoulda known they'd be Beamer seeing whats in the garage with the Dolly. Congrats on getting it running, it's always a big shot in the arm when a project like this fires up for the first time! all the best Steve
Re: Redtop sprint
Right then.
Bought some air filters, they fit even with the bonnet closed which surprised me. Gearbox tunnel fitted. Oil breather fitted.
Now need to buy megajolt ecu so I have active ignition and sort a sliding joint for the back end of the prop.
Then MOT time...
Then MOT time...
- mbellinger
Re: Redtop sprint
Ah yes, I remember that noise so well.....
Looking really good now Ian. Very neat expansion tank installation.
Martin.
2021 Dacia Duster 1.3 TCe
1963 Austin A40 Rally Car
Re: Redtop sprint
mbellinger wrote:Ah yes, I remember that noise so well.....
Thanks. Prop was dropped off today. Hopefully the car will be mot'd by end of March. Expansion tank is a good fit. As advised by Carledo, works very well.
Only change I would make is to fit the engine flat and not at a 7 degree tilt. This gives more room for bigger air filters and should allow more room for a bespoke exhaust manifold on the other side. Also the competition engine mount bushes might be changed for some softer ones, i'll decide once I have run the engine in. Other than that I am very pleased with the outcome at present.
Ian
Re: Redtop sprint
Hi Ian, She's looking the dogs now with those filters and all! Aol buffering has prevented me listening to the latest sound effects but I have a good imagination! Re your suggestion of mounting the engine upright, I dont think that would work due to the sump design which caters to the 7 degree list. My sump (and almost certainly yours as well) sits absolutely parallel with the rack at 7 degrees and only just clears it! If you lift the lhs of the engine which is the only option, all you do is raise the engine in the car and affect the oil pickup and dipstick reading. For my next project I intend to fit an Omega sourced 2.0 Ecotec 16v and autobox to (probably) an 1850 shell. Since the blocks are the same the sumps will interchange but I think the Omega engine sits upright or very nearly, so that might be a way round it. I'll let you know when i've done a bit more research and doubtless the project will appear in a thread! Steve
PS there's a Triumph nut up here who is an ally fabricator by trade, I'm quite sure he would build you a plenum/ airbox to your own design for sensible money. I've seen the one he made for his own efi GT6 and it's stunning!
Re: Redtop sprint
Carledo wrote:Hi Ian, She's looking the dogs now with those filters and all! Aol buffering has prevented me listening to the latest sound effects but I have a good imagination! Re your suggestion of mounting the engine upright, I dont think that would work due to the sump design which caters to the 7 degree list. My sump (and almost certainly yours as well) sits absolutely parallel with the rack at 7 degrees and only just clears it! If you lift the lhs of the engine which is the only option, all you do is raise the engine in the car and affect the oil pickup and dipstick reading. For my next project I intend to fit an Omega sourced 2.0 Ecotec 16v and autobox to (probably) an 1850 shell. Since the blocks are the same the sumps will interchange but I think the Omega engine sits upright or very nearly, so that might be a way round it. I'll let you know when i've done a bit more research and doubtless the project will appear in a thread! Steve
Thanks for the comments. I think you are right with the sump, redtops in caterhams do run OK with 7 degree sumps though in an upright installation. I think my issue would be raising the engine even further to avoid the sump fouling the steering rack. This in turn will raise the carbs and hence they will then start to foul the bonnet.
Medium term I need to get an airbox manufactured as the filters will be OK but I don't think they will flow 200+bhp! When you say up here where is up here?
Ian
Re: Redtop sprint
knightrider150 wrote:Really like this car - reminds me alot of my car
I feel we may be racing each other to the finish line...
Re: Redtop sprint
Shropshire! as per your signature. Not that far from Shropshire...iandollysprint wrote:Carledo wrote:Hi Ian, She's looking the dogs now with those filters and all! Aol buffering has prevented me listening to the latest sound effects but I have a good imagination! Re your suggestion of mounting the engine upright, I dont think that would work due to the sump design which caters to the 7 degree list. My sump (and almost certainly yours as well) sits absolutely parallel with the rack at 7 degrees and only just clears it! If you lift the lhs of the engine which is the only option, all you do is raise the engine in the car and affect the oil pickup and dipstick reading. For my next project I intend to fit an Omega sourced 2.0 Ecotec 16v and autobox to (probably) an 1850 shell. Since the blocks are the same the sumps will interchange but I think the Omega engine sits upright or very nearly, so that might be a way round it. I'll let you know when i've done a bit more research and doubtless the project will appear in a thread! Steve
Ian
Re: Redtop sprint
Dunno why, but I got the impression you were in the London area, must be going mad! (GOING???) I'm in south Shropshire and my mate the fabricator is in Stourport on Severn, Worcestershire. Steve
- ToledoZombie
Re: Redtop sprint
Great stuff, now lets see a video of it in action . .
Hi Ian......
Been watching your progress with great interest and am pleased you are now mobile.
Now you have reached this point, I have a couple of questions to ask, if I may.
If not, how does the car drive?
How is the gearbox mount?
It looks to me like you used a Dolomite o/d one?
A Sierra mount is very similar but a bit bigger. I have adapted a Dolomite o/d crossmember to accept one and am hopeful it
will be an improvement.
Did you do anything about replacing the member from the front subframe you removed?iandollysprint wrote: Front subframe - I think eightiesflamer(?) redtop conversion does not use any replacement. I think it would be relatively straight forward to use the original sprint mounting holes and fabricate with box section a replacement for the bit I have chopped out. I will probably do this.
