I'm slowly but surely rebuilding my waterpump at the moment.
The impeller is currently away being machined.
I'm having the machining done to fit a ceramic 'polo' to mate with the graphite seal. Reputedly cures water leaks forever.
See here....
http://www.ldparts.co.uk/shop/shop.php? ... d6f774341b
See current photos below for an assembled pump prior to recon, and a stripped pump (minus impeller) + repair kit .
I'll post the impeller pics when I get it back.
At the top of this pic is the disassembled waterpump.
I used string to help me remember the assembly order and orientation.
The bottom part of the board shows the repair kit from Tony Hart.
The only things different for my application is that I will source a new circlip and use the graphite seal which matches up to the ceramic 'polo' insert. I have a sneaky suspicion that the graphite seal will be identical to the one shown. I still need the ceramic part though
