NEED HELP FRONT PANEL & PASSENGER SIDE WING
andrew jones
#1 Post by andrew jones »
triumph toledo.jpg (11.56 KiB) Viewed 4117 times
hi ive just bought a triumph toledo 1.3 1973 its passenger wing has damage ive been told that there isnt much chance of a steel replacement wing but i could get fibre glass ones one here could any one give me a price on the wing please also do you do front panels im thinking about changing it as its not brilliant !! the car is fully road legal and love driving her i dont like the droopy toledo headlight haha thanks andrew
grifterkid
Re: NEED HELP FRONT PANEL & PASSENGER SIDE WING
#2 Post by grifterkid »
I believe you can get a glass fibre wing from the club for about £90 but I'm sure somebody on here will give you the precise information you need...
Failing all that why not try and source some good second hand metal panels (?), you might save yourself a few quid...
Good luck with the Toledo, it's a great choice of car...!
#3 Post by JPB »
Yes, that's the price to club members so you'd be well advised to join for that and the other GRP parts and mechanical spares available.
There is the steel option but the one I have in mind - which is as new and still in transportation primer - would cost more than a pair of GRP ones and a GRP front end combined. I've seen and examined at close quarters a car fitted with Alun's GRP panels and the fit is superb. You simply can't tell by looking that they're not steel.
Another option, and one that would save you removing the rest of the wing if it's otherwise good, would be to cut a repair section from a scrap car and weld that in.
Good luck with this and please, keep coming back and asking questions. It's what we're here for. :)
andrew jones
#4 Post by andrew jones »
thanks for your quick replies :D the wing is damaged near where it meets the doo so im thinking it may be easyer to replace the whole thing !! just another question ive got a slight rumble noise coming from around the gear box when setting off do ya think it could be the gear box mount ??? thanks andrew
DavePoth
#5 Post by DavePoth »
It may still be worth getting the wing repaired - probably best to get a few garages to take a look before spending out any money.
Rumble from the gearbox area could be that, but also other things too. The gearbox mount is the easiest one to fix though, so best to check it first. :D If it is the gearbox mount, the stick will probably shake quite a lot at idle. Best to get your head underneath and take a peek.
andrew jones
#6 Post by andrew jones »
the vibrations not so bad if your tentative with the throttle its when ya put your foot down its vibrating from the gear box + front of the car ive been told either as you said gear box mount or could be drive shaft rubber can ya still get both of these parts please if so how much ?????
DavePoth
#7 Post by DavePoth »
Propshaft -yes.
http://www.rimmerbros.co.uk/Item--i-GRID008478
Gearbox mount - yes.
http://www.ebay.co.uk/itm/Triumph-Dolom ... 41664e8958
Those may not be the best prices (although I think you'll have trouble beating the gearbox one) so shop around.
As I say, get underneath and have a look - if it is rubber bits that are knackered they will look quite obviously knackered.
#8 Post by Carledo »
A Knackered prop centre bearing looks like this! Steve
andrew jones
#9 Post by andrew jones »
thanks guys so glad i joined this forum youve been so much help thankyou !!!! im joining dolomite club on payday :-)
#10 Post by xvivalve »
GRP wings are now £100.00 each to Club members, there is also £20.00 P&P to factor in, but collection is welcomed.
