1977 Russet 1850HL 2.0 Auto
Powderfinger
Re: 1977 Russet 1850HL 2.0 Auto
#31 Post by Powderfinger »
Powderfinger
#32 Post by Powderfinger »
Went for an MOT today... and it failed :(
The electrics decided to commit suicide in the last 30 minutes before the test, I lost the horn, then the indicators, then all the gauges as well. Then it blew the fuse so I replaced that but the fuse box is so corroded everything flickered. Then the indicator stalk fell out... :roll: Joys of classic cars eh? It also failed on a slightly perished brake hose so I'll be replacing both hoses and fixing these damn electrics when I next go home. I have two weeks before the retest which is good. I've got a new fusebox on order (reproduction of the original type) and I'm now on the look out for some brake hoses.
James
#33 Post by JPB »
PM sent re the flexies. :wink:
#34 Post by Toledo Man »
You did better than I did with Brown's MoT back last August. A testament to all your hard work.
Aar0sc
#35 Post by Aar0sc »
Shockingly my car's passed every MoT of it's life with one original rear flexi hose!
Powderfinger
#36 Post by Powderfinger »
I am rather embarrised to admit that I still haven't taken the poor Dolly for a retest or found some new brake hoses for sensible money. My budget is very stretched after my job fell through and 2nd gear syncro has gone on my daily drive.
I have sorted out the electrics though with a new fusebox and some soldering. The earth strap for the horn had come out and it isn't possible to get it back in so I glued the stalk in and soldered the earth to it. Seems to do the trick.
I've also converted the lovely radio to work through a 3.5mm jack input as well as the original MW/LW. It's pretty unobtrusive with only two solid connections required on the circuit board and a small hole in the facia, which wasn't necessary but I think looks smart and is convenient. I'm considering doing these conversion to try and get some dosh in so I can get the poor girl back on the road, I know I can undercut the £150 ones seen on eBay by a looooong way. I'll get some photos up later.
James
tinweevil
#37 Post by tinweevil »
James, let me check in the loft tomorrow but I may be able to sort out brake flexis for you.
I had a load of NOS ones that I just won't use because braided are so much better. I've wanted to throw them but I don't think I could bring myself to do it. I sold one set and felt enormously guilty about taking money for something I don't consider up to using on one of my cars. So there they sit annoying me.
As I say, I need to check I didn't get all determined and bin 'em.
Powderfinger
#38 Post by Powderfinger »
Thank you very much tinweevil! :)
Modified radio
tinweevil
#39 Post by tinweevil »
Bad news - they've gone. Good news - not in the bin. They went to whydidistartthis for much the same reason. This lot here. I asked him to keep any left over so fingers crossed and PM sent asking. Mean time I have found one more NOS here, 12 & 3/4" between the points marked in the link.
Powderfinger
#40 Post by Powderfinger »
Not to worry tinweevil, I managed to get a pair the right length on eBay for sensible money at last and fitted them today. I just need to replace the upper axle link bushes as they were advisories. Is it worth dropping the axle out to do that?
James
#41 Post by Carledo »
Its not necessary or particularly desireable to remove the axle to to replace the upper arm bushes, just take 1 arm out at a time and the other will hold the axle (mostly) in place for you, making the job simples!
Oh and at the back end use supaflex bushes for better wearing characteristics and improved road manners!
Powderfinger
#42 Post by Powderfinger »
Thanks Steve, I'm glad about that! I got the bushes ages ago, they're not branded but I think they may be poly, they're pretty stiff anyway and will hopefully help cure the dodgy handling.
I'm also looking at adapting a Mini type Lucas 45 or 65 distributor to fit. I've got a spare Delco and loads of Mini dizzys so I stripped one down and fitted the Dolly drive. The shaft is a bit long so the gear would sit too far in the engine but I think I can cut off the mount from the Delco, get it ground down at the local machine shop to the right height to get the Mini dizzy at the right height above the engine and provide a way of locking the new type dizzy.
Does anyone have the spec of the standard Delco dizzy with regards to total mechanical advance and vacuum advance?
James
Powderfinger
#43 Post by Powderfinger »
Just made a start at the dizzy conversion. The shafts are the same diameter but the body of the Delco is wider so I had to rethink. I cut base off the Delco above the mounting plate and cut the Lucas through the mount. I just used a hacksaw but with some blue and a file I've got the faces pretty good, hopefully I won't need to splash out on a trip to the machine shop. The Delco mount just needs a few thou taking off and it will all line up. I need to figure out who to fix the two parts together now, I've got some Aluweld stuff laying about that I've not really tried yet, hopefully that'll be up to it...
James
EDIT: http://www.youtube.com/watch?v=nxtmt6QCVd8&feature=plcp
#44 Post by Toledo Man »
Why go to all that trouble when you can fit the Lucas 44D4 dizzy as used on the Sprint? The only "issue" with using these on non-Sprint slants is the advance curve. They are compatable with the 45D4 dizzy as used on the OHV engines, the points are easier to adjust and you have more options for electronic ignition. You've already taken a step in the right direction by ditching the Delco.
Powderfinger
#45 Post by Powderfinger »
I'm going to the trouble because I can't really afford to buy a new dizzy and don't really see the point when I have both parts laying around in the garage.
The advance curve in the ACDelco is a joke with only 7.5-8.5' advance (1' tolerance!! :roll: ) so good performance across the range is never going to happen. I can't comment for the standard advance for the Sprint part but the 45s and 59s are pretty simple to adjust. A good start point is 10' centrifugal advance giving 20' at the crank so the engine can be set at 14' idle and 34' max. There shouldn't be any pinking at all at the top end and if the bottom end pinks at all it's very easy to increase the total advance and get rid of it. After 30 odd years the condition of the springs is playing a far greater roll in dictating the curve rather than factory specs so I'm not to worried, I've got plenty of springs to play with.
James
