Sprint recon Engine cost?
Venger
#1 Post by Venger »
Hiya!
Just wondering if anyone can tell the 'going price' for a working engine - maybe a recon. I'd appreciate a guide price for a short engine, as well as a running one with everything on it.
SprintMWU773V
TDC Staffs Area Organiser
Re: Sprint recon Engine cost?
#2 Post by SprintMWU773V »
It largely depends on the components used. Use cheap components and find a cheap machinist then you'd be looking at anything from a few hundred up. However you might want to take a punt on a used engine which could be £50 up on Ebay, however it'd be foolish to stick that straight into a car without giving it the once over. You pays your money and takes the choice.
I assume you have a faulty engine?
Venger
#3 Post by Venger »
Thanks for that. Mine's not faulty as such but it's done a lot of miles - it went round the clock back in 1991 and I can't see anything that suggests it's a replacement. That, combined with a lack of any history with the car (except the old MOTs) makes me want to whip the engine out and give it a good going over. I'd like to take my time over it and so fancied popping in one that had been reconditioned, or at least known to be running well, in the meantime to keep on motoring. :)
#4 Post by xvivalve »
My original sprint has 248,000 miles on its original engine.
My track car had £4,500 thrown at its engine and I managed to use it three times before a £5 component failed necessitating a further rebuild.
These are the two extremes. I'd suggest you test your 100k engine and find out how bad a shape its really in and if it ain't broke then why consider 'fixing' it?
Venger
#5 Post by Venger »
xvivalve wrote:My original sprint has 248,000 miles on its original engine.
It's coming out of the car anyway so I thought I might as well do some work on it. Good to know that yours did 200k+ - mines not there yet, haven't got the old MOTs to hand, and the speedo was replaced, but IIRC I'm on about 160k - it's just warming up :)
DavePoth
#6 Post by DavePoth »
A compression test and oil pressure test are good indications of whether you need to strip the motor down - if you've got good compression and oil pressure it's probably not worth a strip down.
#7 Post by Mad Mart »
I'd strip it down regardless, just for the fun of it. :D
#8 Post by Jon Tilson »
You dont have to put a Sprint lump in it.
A TR7 one will fit....and go well enough while you sort yours and be a lot chepaer to boot.
Venger
#9 Post by Venger »
Jon Tilson wrote:You dont have to put a Sprint lump in it.
ooo good idea. thanks for that!
minidave
#10 Post by minidave »
Hi pm sent Dave.
nashy4
#11 Post by nashy4 »
yes tr7 is a good option thats what i have just put in my sprint and if its reliable it will stay in :D
#12 Post by soe8m »
DavePoth wrote:A compression test and oil pressure test are good indications of whether you need to strip the motor down - if you've got good compression and oil pressure it's probably not worth a strip down.
A compression test only shows that there are pistons and valves in the engine. A leaktest does show the condition.
beans
#13 Post by beans »
nashy4 wrote:tr7 is a good option thats what i have just put in my sprint and if its reliable it will stay in :D
So it will probably stay in :mrgreen:
And it isn't that difficult to get a few extra horses out of it without ruining it's drive-ability and fuel consumption.
