Steering intermediate shaft
Paul Roberts
#1 Post by Paul Roberts »
Hi have a fair amount of play in the steering of the Silver Sprint. Looks as if the splines on the intermediate steering shaft have worn and possibly the flexible coupling the shaft goes into. Ideally I would like to replace with Triumph parts (new old stock) rather than reproduction. Any names to get in touch with?
Paul Roberts
Perth, Western Australia
intermediate shaft.jpg (385.63 KiB) Viewed 2217 times
80Sprint
Re: Steering intermediate shaft
#2 Post by 80Sprint »
As this is posted in the Motorsport section why not go aftermarket or is it the wrong section. A solid mount would be better but not sure you want to go that route.
baz
#3 Post by baz »
Hi Paul,
On my Dolly's I have always replaced the "flexible"uni joint with a "solid" type uni joint. i believe a shotened down one from a 2500 isteering column is used. I can try to get a pic of mine over the weekend but I am sure Dave would know about this mod.
Baz
Yes ............
#4 Post by sprint95m »
It is possible to use a T2000 manual steering upper UJ in place of the Dolomite lower joint.
It is also possible to recondition a Dolomite lower joint using Superflex bushes.
Upper Dolomite intermediate shafts should be replaced with new.
Paul Roberts
#5 Post by Paul Roberts »
Thanks for this. Yes, would very much like to replace with new - problem is finding the new part. Canley Classics can't help and Quiller can only do S/hand. Any other suggestions?
Thanks Paul
minidave
#6 Post by minidave »
Hi i got my solid type from winns Dave.
